2010 - Help! Disabling Reverse Beep
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sherryp, May 30, 2009.
  1. Todor
    Todor Junior Member
    85
    23
    2013 Chevy Volt
    Guys, I'm trying to develop an app for Android that does exactly this: disables the reverse beep and allows you to configure other things as well, without geeking out with the ELM terminal. Anyone wanna give it a try? I haven't released it yet, but I'm looking for people to test it now. It'll be free for the testers. Post here if you're interested and I'll let you know how to get it. Thanks.
  2. peterjmc
    917
    188
    Clarksburg, MD
    Is there a Bluetooth ODB II interface requirement?
    Nexus 5
  3. pmike
    pmike Member
    233
    Central Florida
  4. Michael999
    Michael999 Junior Member
    Eastern Ontario, CANADA
    Had mine disabled but ... they could only change it from a continuous beep to a single beep, and it cost about $30.
    Bizarre that I have to be reminded I am going in reverse, and why on the inside. It's actually distracting and cound increase the chances of problems.
  5. Todor
    Todor Junior Member
    85
    23
    2013 Chevy Volt
    Yes, you need an ELM327 Bluetooth device. Any cheap ELM327 with Bluetooth will do.
    That looks interesting, but again it requires a lot of custom setup. My app should be able to do it with a few clicks, and no technical knowledge required.
    So, anybody wanna try it? It can also set many other settings, not just the reverse beep. It does not show live data though.
    FrankB likes this.
  6. pmike
    pmike Member
    233
    Central Florida
    A YouTube video of either the ELM terminal or Torque method would probably work just as well.
  7. dragonfly13
    dragonfly13 Junior Member
    I'd like to give it a try. Are you considering doing something with the navigation system? I'd like my passenger to be able to Input addresses on the fly as I drive.
    Todor likes this.
  8. FrankB
    FrankB Member
    117
    53
    I've got an ELM327 Bluetooth device. I've already modified my reverse beep using Elm 327 Terminal, but I'd be happy to try out your app for other settings.
    Frank
    Todor likes this.
  9. Todor
    Todor Junior Member
    85
    23
    2013 Chevy Volt
    Great, you guys both have messages from me!
  10. FrankB
    FrankB Member
    117
    53
    Wow. I've used Torque, ELM327 Terminal and they get the job done. But your app is by far the easiest to use. Bravo!
    Frank
  11. Tropicseed
    Tropicseed New Member
    I think it's actually a matter of hooking up a laptop (or even a special computer) with the right Toyota service software. The manual for my 2013 Three lists quite a few options you can change, with 3 levels of "accessibility":
    - if you have the base head unit you get a few
    - the HU with satnav gives several more
    - and there are a few that only the dealer can change
    I think it's quite unlikely that changing options is done as "easter eggs" these days. Much easier just to not have them available from the normal GUI and require the Toyota program for access.
    If you poke through this thread, there are many who have had the reverse beeping turned off by the dealer, or by themselves with special equipment. I'll get it done when I take my Prius in for its first service. I believe you can also have the climate control changed so the auto setting does not turn on the AC, which I would prefer.
    Personally, I would rather have the dealer do it as they would have the liability. I'd hate to get a hex number a bit wrong and change something important without realizing it!
    Patrick
  12. FrankB
    FrankB Member
    117
    53
    You can change the AC auto setting among other things. Todor's app puts it all in a GUI on Android if you have a Bluetooth ELM327.
    Frank
  13. Tropicseed
    Sure, i'd love to try it! If you noticed my post earlier today,I was put off by the terminal emulator complexities, but your app sounds great.
    patrick
  14. Todor
    Todor Junior Member
    85
    23
    2013 Chevy Volt
    Thanks for the feedback Frank! Tropicseed, I'm sending you a message with the details on how to get the app.
  15. pmike
    pmike Member
    233
    Central Florida
    I would like to check out your app.
  16. Todor
    Todor Junior Member
    85
    23
    2013 Chevy Volt
    You have a message. Thanks!
  17. David Foxworth
    David Foxworth Junior Member
    I would like to take a look at your app also.
  18. Todor
    Todor Junior Member
    85
    23
    2013 Chevy Volt
    You have a message.
    For everyone who is interested, the app is called Carista and you can get the beta-test version that has the new Toyota customizations from this page:
    Carista Beta-Testing | Prizmos Ltd
    Thanks!
  19. gmay013114
    gmay013114 Junior Member
    NC
    I just read some of the posts in this thread, didn't read all of them. I was able to get the dealer to reduce the reverse beep to one beep, said they couldn't turn it off completely. I also tried to get them to change the A/C to not go into recirculate mode when the system was set to Auto, nothing worse than hot air being blasted in your face when starting the car on a 95 degree day. They said it couldn't be changed, so I just keep it in manual mode. Is there a way to change the system so that it doesn't go into recirculate mode and come on full blast every time, also comes on full blast when pressing the front defrost button as well. Worse heat and A/C system I have ever used, simple dials would be much easier to use.
  20. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Have you tried raising the temperature? Are you in ECO?
