2010 Prius AC only turns on through defroster
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Riotmode, Aug 4, 2021.
  1. Riotmode
    Riotmode New Member
    makes sense. I'll give it a try, though if you know how to actually get the dang thing off that would be helpful info.
  2. ChapmanF
    19,041
    Follow this old post here. Then start your fingers behind the right edge of the bezel that goes around the heat controls and radio, and pop that out. Then grasp the heat control panel and pull it out.
  3. Riotmode
    Riotmode New Member
    No dice, I got the cover off but there doesn't seem to be a way to remove the actual AC part. I still got a bit of spot-cleaning done through it, but the buttons all seem functional, just... unresponsive.
    Is it possible this is a problem with the computer? I know the right half of my dashboard display is burnt out, could that be relevant?
  4. Riotmode
    Riotmode New Member
    Still hanging around folks, just giving the thread the ol' bumparoo
  5. ChapmanF
    19,041
    Nothing but clips. Just pull on it, once the trim is off from around it.
  6. heymelimel89
    heymelimel89 New Member
    Oklahoma
    Were you able to figure out the solution for this? I am having the SAME issue with my 2011 Prius
  7. ChapmanF
    19,041
    If the behavior is exactly the same, then go ahead and try the same approach as above.
  8. Garo Barsemian
    Garo Barsemian New Member
    Glendale
    We’re you able to find a solution? I have the same exact issue as well LOL
    Any news? Did you figure it out? This is my only hope
    #28 Garo Barsemian, Aug 4, 2022
  9. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    Has anyone with these symptoms actually had the refrigerant level checked? A leak is the most common issue. Or a high pressure fail such as a dirty condenser? The defrost operation may be a programmed override. @lech auto air conditionin
    #29 rjparker, Aug 4, 2022
  10. ChapmanF
    19,041
  11. REPRIEBE
    REPRIEBE New Member
    Mine had this exact same problem. It turned out to be the A/C switch in the HVAC unit. Unfortunately, contact cleaner would not help mine - it was too far gone. I wound up getting a broken HVAC unit, desoldering the two switches (my bad one and a good one from the broken unit) and soldering the good switch onto my board. It now works like a champ!
    douglasjre likes this.
  12. ChapmanF
    19,041
  13. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    What's the data look like on techstream
  14. REPRIEBE
    REPRIEBE New Member
    I never had mine hooked to techstream, but the self test came back 00 - no problems. I also could not believe how easy it was to remove the control unit - NO SCREWS! Just unclip the trim, unplug some wires, unclip the HVAC unit by pulling straight out on it and unplug it - too easy!
    AndryArt and Garo Barsemian like this.
  15. Garo Barsemian
    Glendale
    Hi there! Could you please go into a bit more detail on what exactly you did? From what I understand the ac button itself wasn’t working properly because of the switch? So you pulled the trim and got out the unit with all the climate controls on them correct? I’m just trying to learn a bit more as I have the exact same symptoms. Thank you so much in advance!
    AndryArt likes this.
  16. AndryArt
    AndryArt Junior Member
    Bucharest
    can you give us more details of what did you do that worked for you? I already spent 800€ changing the compressor as the Toyota Dealer checked with diagnostics, weird, I checked with my Carista and techstream No errors, same symptoms as the OP. Looks like the issue is the same but for a while neither works with the defrost button together, worked with the button near left, now nothing. I pretty sure the dealer scammed me, changed the compressor, refrigerant…nothing. Hope the is button issue, already spent a lot for used spare OEM parts as the new ones get over 1500€.
    I would really really appreciate it if you could reply with any info. Thank you very much!
