2010 Prius Blown Headgasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by electrontechnik, Jul 14, 2015.
  1. Den49
    Den49 Member
    498
    272
    Maryland
    electrontechnik - How many times, and at what mileage, in 192,000 miles did you change the engine coolant?
  2. electrontechnik
    117
    31
    It was never changed when I owned it, but i have been checking it every 20k or so ( bought it at 80k) with a antifreeze check instrument. Still looking good...all the balls floating in the tool.
  3. Den49
    Den49 Member
    498
    272
    Maryland
    Coolant deteriorates, becomes acidic and dissolves cylinder head gaskets. Not changing engine coolant before it goes bad is a major cause of blown head gaskets.
    The balls floating in your tester measure freeze protection, not PH. PH is measured with test strips that turn color to indicate numerical acidity. New coolant is typically 8 to 9. 7 is neutral. Below 7 is acidic.
    #23 Den49, Jul 15, 2015
    CR94 likes this.
  4. electrontechnik
    117
    31
    I checked my coolant with the multimeter voltage test and found the following result: The coolant is still good. The multimeter test is a substitute for the acid test strips. As coolant ages and exhaust gases turn the coolant acidic, the coolant system becomes a battery and electrolysis causes internal damage. Hence the need for coolant changes over time. So yes, /u/Den49 is correct, but at this time my coolant is still good.
    Here is the coolant multimeter test procedure: Test procedure
    And a video (not mine):
    0.2 V to 0.5 V - good
    0.5 V to 0.7 V - due for a change
    0.7 V or over - change it now.
    And one more for good measure:
  5. Den49
    Den49 Member
    498
    272
    Maryland
    electrontechnik - Thanks for the video. Conductivity testing is a good test but not an absolute indication of coolant PH because coolant with a good PH can be conductive due to a bad ground connection that causes current to flow through the cooling system and register on the meter.
    Also, the video states that the meter reading for good coolant should be under 0.05 V (not 0.5V). The meter readings you show in the above pictures are 0.17 and 0.14 which are much higher than 0.05, indicating very bad coolant.
  6. electrontechnik
    117
    31
    Yeah his digits are off in the video, everywhere else is confirmed that the correct range is 0.X not 0.0X. In the comments for the video and the article link you can see this. I just linked his video because it was the first one I found.
    Also, I should add, I conducted the test with the car in the off mode, not turned on at all, so there is no interaction with the car's 12v or hybrid systems.
    Edit: looks like I'll have to go to a garden store for pH test strips, no auto supply around here has them :(
    #26 electrontechnik, Jul 16, 2015
  7. Den49
    Den49 Member
    498
    272
    Maryland
    That's a relief. Hope everything goes well with the repair and your Prius is restored to good health. Good luck.
  8. Mendel Leisk
    42,208
    I hate it when someone tells you to do something, but not the reason for doing it. I learned a very specific reason in this thread, for timely changing the coolant.
    Atari likes this.
  9. Former Member 68813
    3,524
    983
    US
    i've heard about it and have huge reservations. there are too many variables. type of metal in the meter electrode and engine, internal meter resistance, etc.
    if one wants to pursue coolant testing, there are commercial testing strips, not cheap last time i checked. it's easier just to change coolant every 100,000 miles IMHO.
  10. electrontechnik
    117
    31
    I understand the meter probes could change the results a small amount (probes high in plated copper vs. other metals), but how does internal multimeter resistance affect it?
    In any case, I am working to get some PH test strips which will settle it once and for all.
    Oh and... When to Replace Engine and Inverter Coolant? | PriusChat
  11. bisco
    52,719
    there are so many unknowns, i don't even know what 'clean looking coolant' means? it seems prudent to change it at factory recommended intervals. or more often if you intend to keep the car for several thousands of miles.
  12. Patrick Wong
    18,210
    6,517
    This means that if the coolant were poured into a glass and a few ice cubes added, you would not hesitate to drink it. (Of course, antifreeze is poisonous so this would be a very bad idea.)
    With some vehicles, when the coolant is changed at the manufacturer-specified interval, the drained coolant contains debris and looks/smells nasty. This usually is not the case with the Prius.
    In any event, I think the OP needs to change the coolant now, if it is the original fill - way past due.
  13. Den49
    Den49 Member
    498
    272
    Maryland
    You want to change the coolant before it goes bad. Bad coolant allows corrosion which is what you want to prevent. Therefore, the coolant that comes out of the engine when it is changed should look just like the coolant you put in, if not you waited too long to change the coolant.
  14. bisco
    52,719
    can it be bad, even if it looks good?
    slamm3r_911 likes this.
  15. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    And this is why I got my coolant changed at the dealer last week for $100. Honestly I'm super cheap, but is having to rebuild your engine worth it? I feel really good about spending that money, honestly. And I NEVER go to the dealer (diy oil changes all the way!). Just look at it as insurance
    PriusGuy32 and Den49 like this.
  16. Mendel Leisk
    42,208
    How'd that go? They managed to avoid air pockets, did a decent job?
    I do hope they drain the block as well; a few posters have mentioned they sometimes just drain the rad.
    I did a civic coolant change recently: a blinking deluge came out of the block.
  17. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    They did a complete engine coolant flush. They did a great job, no air in the system, also quick service and friendly people. My dad asked me if they pushed other services on me, or tried to sell me stuff I didn't need, I said "nope! You can't sale any services to a car with 260,000 that is in perfect mechanical condition!" The worst thing about my car is my paint!
  18. electrontechnik
    117
    31
    #38 electrontechnik, Jul 22, 2015
    Umar Ali, m.wynn, Den49 and 1 other person like this.
  19. Patrick Wong
    18,210
    6,517
    What did the drained coolant look like? Per your post #30, did you use pH strips on the drained coolant?
  20. electrontechnik
    117
    31
    The drained coolant was slightly redder but still pink, but I haven't drained the radiator yet, still a gallon or two in there. I've saved a sample for pH testing, since I got a liquid pH test kit (used for soil, but could be for anything else) and it tried it and it was inconclusive. Need to go to more garden centers...the big box stores are no match...I spent an hour looking for the strips and the closest I got was the pH liquid.
    But it did occur to me after the fact that I could go to a aquarium store as well as a pool supply house.
