2010 Prius No Power until car is on...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Juan Julian Gonzalez, Mar 1, 2018.
  1. Juan Julian Gonzalez
    Wildomar
    Hey guys,
    Im looking for some help. So my Prius is acting like is has a dead battery but when i go to start my car it starts right up. My keyless entry wont work at all, i cant unlock or lock the car from the inside and i cant use the push to start unless the key fob is on the button itself bypassing the key fob detection. Also once i start the car it doesn't retain any information like my trip meter, tank range, or time but it keeps my radio stations saved. could it be a fuse?
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Try changing the key fob battery and see if it helps?
  3. Juan Julian Gonzalez
    Wildomar
    The key fob battery and the car battery are brand new
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Does the red light on the fob light up?
    Are the leads for the battery tight on the new battery?
    If you think it is a fuse, you could check under the hood and while there, check the voltage of the 12v battery;).
    Keep us posted (y).
    m.wynn likes this.
  5. Juan Julian Gonzalez
    Wildomar
    Yes the red light lights up on the key fob.
    Just to make sure I removed them cleaned them and reinstalled them and assured they were tight.
    the voltage is correct, and currently testing fuses under the hood and inside.
    m.wynn and Raytheeagle like this.
  6. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    What voltage are you measuring on the 12v?
    The battery leads are tight on the 12v? This includes the body ground?
    m.wynn and bisco like this.
  7. bisco
    52,858
    welcome!
    how many miles on her?
  8. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    edited for wrongness.
    #8 m.wynn, Mar 2, 2018
    Raytheeagle likes this.
  9. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    No SKS button on the 2010.
    Raytheeagle and m.wynn like this.
  10. m.wynn
    684
    1,230
    Queensbury, NY
    My bad, thanks for the correction.
  11. RRxing
    2,564
    1,842
    NEPA
    I had a key fob issue issue with my 2010. The only thing that seems to be different is that the OP cannot lock or unlock the car from the inside (unless the OP meant outside.) I never did find a cause, and sold the car in August 2017.
    Rapid Key Fob Battery Drain | PriusChat
