2010 Prius will not start after sitting for 6 days in snow
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TrvlArrngr, Jan 8, 2018.
  1. TrvlArrngr
    TrvlArrngr Member
    33
    26
    I live in Emerald Isle NC. It is 41 degrees right now. We had a freak snow/ice event here and i did not touch it for 6 days. finally got above freezing yesterday. In the 50's. Rest of this week will be in the 60's. it's bizarre.
    padroo likes this.
  2. TrvlArrngr
    TrvlArrngr Member
    33
    26
    Is ready state when the start button turns green? When i put my foot on the brake it does turn green. Only the inside accessories work though. Heat, radio, lights all work really good.
  3. TrvlArrngr
    TrvlArrngr Member
    33
    26
    No I watched him. He did it like they say to do it online.
    51,961
    are the headlights bright? if so, it probably isn't the 12v battery. to me, if the ready light is green, it should start.
    maybe an issue with a blown fuse or something like the dome light.
  5. TrvlArrngr
    TrvlArrngr Member
    33
    26
    I forgot to say that on the display the pic of the HV battery is 3/4 full of bars. How do i check the fuses? is it easy to tell if they went bad?
    davecook89t likes this.
  6. bisco
    51,961
    do you have an owners manual? have you tried the headlights while in ready? does the dome light work?
  7. jack black
    jack black Active Member
    225
    142
    I
    no, it's ready (or on) when you can see "READY" on the dash.
  8. TrvlArrngr
    TrvlArrngr Member
    33
    26
    dome lights work, head lights work, brights work too
  9. jack black
    225
    142
    I
  10. TrvlArrngr
    TrvlArrngr Member
    33
    26
    But the 12v goes in the rear. how could he disconnect that one? I found someone with a code reader in the neighborhood through a local site called Nextdoor.com he said he can come over with his code reader. Will post the codes here
  11. jack black
    225
    142
    I
    did you watch the video in the thread i linked?
    if you watched, you would understand that the switch is in the rear, next to 12V battery.
  12. TrvlArrngr
    TrvlArrngr Member
    33
    26
    I do not have the plug thing you are talking about on mine. i watched the video but mine is different ugh
  13. padroo
    padroo Senior Member
    2,763
    2,252
    Thre should be three places for fuses to check, under the hood, drivers side under the dash and some back by the battery. Check your owners manual.
    I am familiar with your area of North Carolina. I remember when there were just a few houses on Emerald Isle back in the late 60's.
    #33 padroo, Jan 9, 2018
  14. jack black
    225
    142
    I
    yes, you do. it's near spare tire and 12V battery.
    TrvlArrngr likes this.
  15. TrvlArrngr
    TrvlArrngr Member
    33
    26
    It's built up now. Still not a lot of full time people like me. I am lucky that I can work from home - no good jobs around here unless you are a fisherman, own your own business, or work from home like I do. I have maybe 3 neighbors out of 20 that are here full time in the off season. Great for many reasons except when you are looking for help with something like a car lol
  16. TrvlArrngr
    TrvlArrngr Member
    33
    26
    Thanks! I found it - i took it out and put it back in and pushed it to the right. nothing changed. ugh
  17. Prodigyplace
    12,567
    11,781
    Central Virginia
    Are you sure the plug is installed cprrectly? Many people do it wrong.
  18. TrvlArrngr
    TrvlArrngr Member
    33
    26
    my negative terminal cable is loose - you can spin it around. does not seem to make a difference for the accessories and lights though. Could this be affecting the HV system? I saw this on another thread. I called Toyota near me and this guy quotes me 700 dollars for a new harness says that is the only way. I laughed and called the dealer I bought it from in Raleigh and they knew right away and it is 49 dollars. they gave me the part number and i called the guy here back and gave him the number and he stammered and said oh that's weird. He would do it for 31.69 do you think this could be it or should i just have it towed over?
  19. jack black
    225
    142
    I
    if the lights work, that should not be an issue. do this, remove the negative terminal cable, keep it off for a few minutes and press brake pedal while off. then reconnect again, tighten with pliers, and cycle off/on 3 times using the push start button (pressing brake pedal). report back with results.
  20. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    A loose negative on the 12V can affect just about everything. And that would explain a LOT since it had been taken off and re-installed with the new battery.
    Prodigyplace likes this.
