2010- Replaced EGR Circuit: Pipe, Valve, & Cooler)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius_Angie, Aug 1, 2020.
  1. Prius_Angie
    Prius_Angie Active Member
    245
    229
    Saint Louis
    Today I removed and overhauled the entire EGR circuit to my 2010 blue Prius (217,000 miles). Over the last 3 months, this was my 4th EGR circuit procedure, updating all 3x of my Prii [and a fiend's Prius].
    MATERIALS
    - mail ordered "used" EGR valve; clean and reused EGR cooler and pipe
    - cleaning solutions: water, purple degreaser, Easy-off oven cleaner, brake parts cleaner, carburetor cleaner
    - pipe cleaning brushes
    - E8 socket
    - 2x lock washer & M5 0.8 16mm to replace phillips-head bolts with hex-head bolts to EGR valve black cap
    EGR PIPE.
    - cowel removal is necessary for EGR valve/cooler/pipe; its a simple process & I've don't it +100 times, but personally I'm not a fan of this task
    - cleaned with combination of purple degreaser, easy off oven cleaner, brake parts cleaner, pipe cleaning brush
    - the bristling pipe cleaning is great for agitation as a bore punch for that gunk removal
    EGR VALVE.
    - pressure wash cleaned & chemical spray cleaned with carburetor and brake parts cleaner
    - Also opened up the black cap & spray cleaned innards
    - 2010- 3x EGR Valves, Preventive Maintenance | Page 2 | PriusChat
    EGR COOLER
    - solid concrete-cooler ridden with thick black carbon soot
    - upon initial visual inspection, i could not see through the cooler
    - liquid could barely pass from one side in-port to the other side out-port
    - car wash pressure washer cleaned
    - 2010- Multiple EGR Power Wash Cleaning, No Chemicals/Soap | PriusChat
    ROAD TEST.
    - ensure you meticulously replug every wire back in place
    - <5 minutes on back roads-- confidence up; parlay...
    - >15 minute road test smooth and sustained 70mph
    - gas pedal throttle is so much more responsive
    - i hope this "used" EGR valve lasts >5 years in combination with new oil catch can emplacement.
    - An earlier comparable EGR procedure... 2010- EGR System Maintenance | PriusChat
    P_20200721_182415.jpg P_20200731_195315.jpg P_20200731_174834.jpg P_20200726_124206.jpg P_20200731_174857.jpg P_20200731_174910.jpg P_20200731_174915.jpg P_20200731_174912.jpg P_20200731_175013.jpg P_20200731_175055.jpg P_20200731_174919.jpg P_20200731_175002.jpg P_20200731_175051.jpg P_20200731_175035.jpg P_20200731_174946.jpg P_20200731_175507.jpg P_20200731_175531.jpg P_20200731_175525.jpg P_20200726_124137.jpg P_20200726_124200.jpg P_20200726_124214.jpg P_20200726_124307.jpg P_20200726_124331.jpg P_20200726_164044.jpg P_20200726_164058.jpg P_20200308_125023.jpg P_20200530_192921.jpg P_20200529_125805.jpg qP_20200529_125751.jpg
    #1 Prius_Angie, Aug 1, 2020
  2. James Analytic
    302
    46
    Michigan
    Awesome detail and thanks for sharing! I'll have to see what is on my 2013... and take a trip out to get x2 - lock washer & M5 0.8 16mm. I think I have everything other than the oven cleaner and rubber hose heat shield sleeve for the PCV Valve relocation and OCC installation.
    Edit Update: I just bought two of these stainless steel M5 0.8-20mm and the stainless steel #10 lock washer package. Figuring worse case scenario, if the bolts are to long, I have to grind them down shorter. Thinking I might head to the self serve salvage yard in the morning for the sleeves if calling around I can't find any for a reasonable price. Plus there are some Prius I've not picked on yet.
    #2 James Analytic, Oct 9, 2020
  3. SB6
    SB6 Member
    324
    71
    Nice! I was kinda hoping you had pictures with the black cap off though. When I did my EGR clean, I was too scared to mess with that part, so I just cleaned around it :unsure:.
    Unrelated, but can someone explain bolt sizing/labelling conventions to me?
  4. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "can someone explain bolt sizing/labelling conventions to me?"
    Assuming you want info on metric bolts, do a search on Metric bolt sizing. You'll get several useful charts on the subject.
    SB6 likes this.
