2010 Transaxle Swap
Discussion in 'Gen 3 Prius Technical Discussion' started by bhh338, Feb 19, 2021.
  1. bhh338
    bhh338 Junior Member
    Kansas City, Mo
    Hey!
    Well at the point of a transaxle swap:
    What lead up to this:
    - Leaking Driver Side Transaxle seal
    - Drained the Transaxle Fluid and found water mixture inside (I've owned the prius for 2 years, never had issues)
    - Flush fluid out, add new fluid, Drove like normal.
    - 2 weeks later, hear a clunking kind of from the transaxle when put into drive
    - Go to flush the new fluid again to clean out the past fluid, to discovered it is mixed with water again.
    - Trying to find the source of water mixture, its NOT my radiator/antifreeze fluid from the engine or Inverter/transaxle (Someone mentioned I may have a cracked housing on the transaxle which is rare, but no where else the water would be coming from.
    - Picked up a trasnaxle for 100$
    Now, to change out I need some help/guidance.
    GEN 3
    Gen 3 transaxle failure/fix at 193,000 | PriusChat
    GEN 2
    https://attachments.priuschat.com/attachment-files/2018/08/151208_Prius_2nd_Gen_-_Transmission_Removal.pdf
    I've followed instructions gotten to the point where I've removed axles, everything around the transaxle and ready to lower.
    My question, for GEN 2 I saw they dropped the crossmember under the engine, DO I NEED TO DO THIS FOR GEN 3? Anybody that has done this swap please let me know. I don't want to drop it if I don't have to, but it is a tight fit to lower it out.
    Please HELP! I've done plenty of civic engine swaps but just changing the transaxle of the prius is a little of a pint to drop under right now.
    Thanks in advance for everybody's help!
  2. Mendel Leisk
    42,376
    I’ve no experience, but anyhoo: think I’d disconnect and pull the engine, then the transaxle, all through the top.
  3. bhh338
    Kansas City, Mo
    Bump it any help would do how to swap just the tran.
