2011 G3 Prius - Gas Sensor Recalibration
Discussion in 'Gen 3 Prius Technical Discussion' started by BigEddye, Jul 23, 2024.
  1. BigEddye
    BigEddye Junior Member
    San Diego CA
    I'm curious if someone have that information to share.
    My 2011 Prius, has an issue on it's gauge, and it's not in the fuel system, but in the electronic gauge.
    I fill it up with gas, and it goes to the top of the gauge, but it's still filling up with another 2 gallons after reach the top of the gauge, them it cut off at the pump,
    When it's going to an end of the gas, it is still showing that has half of the tank with gas, and I run off of the gas three or four times till I learned that something was wrong with the gauge.
    In resume:
    Isn't showing the right information when refueling.
    Isn't showing the right information when need to refuel.
    I know it's just recalibration of the sensor, and if I go to Toyota they can do it, but has a very expensive charge, which I'm avoiding to pay.
    And, I know Techstream also has a way to do, so, I'm asking for orientation, if someone knows how to do that, feel free to teach me, please.
    Obs.: It's a G3 Prius, not the G2, what works for G2, most of the times won't work on G3.
  2. ChapmanF
    18,974
    I am not so sure about any of that.
    I know the combination meter has inclination sensors, which it uses to correct fuel level readings according to whether the car is level, and there is a calibration procedure for those sensors.
    As far as the actual level sensor in the tank, I do not believe there is anything about it that can be calibrated, by the dealer, by Techstream, or by you. If it hasn't got the right resistance-to-level relationship, I'm not aware of any solution other than replacing it,
    So, you could try the recalibration of the inclination sensors easily enough, but if that doesn't turn out to fix your issue, I don't think there is any other "calibration" you can do.
  3. tkc100
    tkc100 Member
    92
    25
    Arizona
    This is how to calibrate a GEN II I don't know if it the same for your GEN III. It's pretty simple and it won't hurt to try. I had to a similar problem after replacing the instrument cluster circuit board.
  4. ChapmanF
    18,974
    Just to reiterate, the steps given there were captioned "recalibrating the fuel gauge", but all they recalibrate is the inclination sensors built into the combination meter to detect when the car is on a slope. The combination meter uses that information to tweak the fuel gauge reading when on sloped ground, so it might make that much of a difference if the calibration has gone off somehow.
    But other than that, there is no calibration of the fuel level sensor itself, either in gen 2 or in gen 3.
  5. tkc100
    tkc100 Member
    92
    25
    Arizona
    I never knew exactly how it worked but here's my story.
    Thank you for clarifying my post.
    After changing the circuit board on the back of the instrument cluster when I would run the gas gauge down to the last square, I was only able to get about 6 gallons of gas into the tank. I repeated this three times with the same results. Each time on level ground.
    After completing the procedure outlined in the attachment, I was able to get a little over 10 gallons of gas in the tank when the gauge was down to the last square. It's been that way ever since.
    BigEddye likes this.
  6. BigEddye
    San Diego CA
    yes, it has, but I still cannot find anything to help me with that.
    Look, the G3 Prius, when you replace anything that has metering system on it, it need to be recalibrated, and, you have only two options, one, go to the dealership and they will charge you $500 to do, or, second, find some independent technician that do it at your choice, and charges you something around $200 to $300.
    Recently, I needed to replace the ABS system, and it cost me $250 only to recalibrate, plus $750 for the part and $300 for the service (in an mobile mechanic), if I go to the dealership, it costs about $3000.
    That's my concern, I don't have any problem running with my car in that situation, but yet, I want to learn how to do it myself, since it is just a simple calibration.
    As I said, the G3 and G2 have an huge difference in some simple stuff.
    And that is one of it... the buttons, the sequences, are all completely different from G2/G3, so, this tutorial doesn't work since the step one, on the G3
    the process for the G2, isn't calibration, that steps are for reset the sensor/computer, and it works very well, you don't have to worry about leveling the car... it's just a reset...
    To recalibrate, yes, you have to level the car, and connect the techstream to your car... and do the calibration from there... somehow
    #6 BigEddye, Jul 25, 2024
  7. ChapmanF
    18,974
    It seems that you may have been getting some information from less reliable sources. If you could add to your posts where you found this information, we might be able to respond in more detail.
    The PDF that tkc100 attached in #3 gives the gist of the inclination-sensor calibrating procedure for gen 2. I would have recommended a person go straight to the repair manual instead (in the old 2006 edition that's often consulted, this is on pages ME-30 and ME-31). These telephone-game versions (it looks like tkc100's PDF file itself was made by watching a youtube video that Hometown Hybrids put up after looking in the manual) usually just get further and further from what you'd have learned by just looking in the manual to begin with, but the one in #3 at least still looks close enough to work. :)
    The gen 2 inclination-sensor calibration was very much like the gen 1. Neither procedure required Techstream. By comparison, looking in the gen 3 repair manual, it appears they did away with the inclination sensors entirely, leaving nothing at all to calibrate. The fuel gauge troubleshooting instructions involve confirming the resistance of the tank level sensor (12 to 18 Ω at full, 405 to 415 Ω at empty, smoothly changing in between); if the sensor doesn't check out you replace it, if the wiring doesn't check out you fix it, otherwise you start replacing circuit boards in the combination meter.
    The only fuel-gauge-related things you can do with Techstream in gen 3 are to view the current reading in the Data List, or use the Active Test to force the display to full, mid, or empty as a display test.
    #7 ChapmanF, Jul 25, 2024
    Brian1954 likes this.
  8. tkc100
    tkc100 Member
    92
    25
    Arizona
    ChapmanF
    Let me be clear, I only shared my experience. I do not profess to be any kind of a Prius expert. I depend heavily on individuals like yourself who give so much to this community.
    You are right the procedure is in the service manual and I will add their are at least several You-tubes that are just flat wrong or very misleading. I think for that I can claim to be an expert.:confused:
