2011 Prius acting very strange
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mandylynn, Jun 13, 2018.
  1. Mandylynn
    Mandylynn New Member
    Ohio
    Hello all! So, I have had my 2011 Prius since it was brand new. It has 107k on it and recently has been acting very strange. Just randomly the other day while driving, at low RPMs it started almost jerking or misfiring and having a smell of sulfur. Did some research and bought some seafoam (in case it was bad gas) and also replaced all 4 spark plugs. Seemed like the issue got "mildly" better after the plug change but it still happening. Misfires and kind of rattles (almost sounds like stalling) between 5-10 mph, and is otherwise fine. Also,once it's driven about 25 for more than 5 minutes or so, it stops completely. Pickup is great and no warning lights.
    So, our next step was going to be replacing engine coils? Good idea? Any other suggestions?
    52,904
    welcome!
    hard to believe no warning lights. i think i would check for codes just in case.
  3. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    I would guess your coils are fine and that you need to clean your EGR circuit along it's entire length. Intake manifold large EGR port and small ports to each of the 4 intake ports, EGR pipe, EGR valve and EGR cooler. This entire circuit needs to be free of carbon obstruction. There are scores of threads regarding this and subsequent head gasket failure when left too long. @NutzAboutBolts has very well done instructional videos posted to their sticky in this forum.
    Your mileage is low enough that there's a solid chance your head gasket is ok, but it absolutely should be ruled out. Check your engine coolant level in the translucent bottle on the passenger fender, and monitor it over coming days to be sure it's not dropping by the day. If it stays at an exact level, you should be in the clear and the EGR cleaning should remedy the "misfire-like" symptoms. If the coolant level is dropping, you'll want to proceed with testing for failed head gasket.
    This said, coil failure is a rarity with these cars, especially at your low-ish mileage. It's also very unlikely a coil(s) causing symptoms you describe would present without the check engine light and an accompanying P030x code(s).
    Good luck. If you need an independent mechanic's help, please post your town or general locale in Ohio.
    qettyz, danlatu, Raytheeagle and 3 others like this.
  4. Michael Mann
    Michael Mann Active Member
    167
    408
    Bay Area, CA
    Sounds like it could use an EGR cleaning and swap out your PCV valve.
  5. orenji
    orenji Senior Member
    5,887
    3,490
    EGR cleaning
    m.wynn likes this.
  6. Mandylynn
    Ohio
    Thanks for the info! The misfires have stopped completely now for two days straight. Also, took to local auto parts store and they found no codes, so, I am hoping maybe it WAS just bad gad and the top tier fuel and sea foam is helping. It has turned into the mystery machine! LOL!
  7. Mendel Leisk
    42,379
    What's with that? Just Beelzebub waiting in the wings, or?
    m.wynn and Raytheeagle like this.
  8. Mandylynn
    Ohio
    Hah. Called local mechanic and was told that the smell of sulfur could be the gas motor burning off bad gas, so who knows. Local mechanic found no fault codes either and cannot repeat the misfires now!
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    The devil smells like sulfur :)?
    How do you know that:whistle:?
    Or is that something you’re not supposed to share :censored:?
    m.wynn likes this.
  10. Mandylynn
    Ohio
    I mean, is it possible that the spark plugs just took a few days to adjust or something? Pickup seems better now, ticking noise and smell are gone, and hybrid battery is charging way faster. I am so perplexed
  11. m.wynn
    684
    1,230
    Queensbury, NY
    Don't laugh boys, sulfur smell seems to be an emerging symptom of turd gens which resolve via divine intervention. Nothing says higher power more than the old dealer EGR valve swap:rolleyes::cool::D...
    2010 Prius: Engine/Battery Rattling, Pulsing at Cold Start/Low Speeds | PriusChat
    Kidding of course. Entirely possible both of these cases are down to a worn out EGR valve and some bad, midwestern gas:sick:.
  12. Mandylynn
    Ohio
    So, is it possible that it’s the EGR if it stopped doing it randomly and isn’t showing any codes? Also, even though it’s acting normal now, should I still get the EGR checked? Thanks! :)
  13. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Yes and yes (although for question 2 I would say cleaned not checked);).
    Good luck and keep us posted (y).
    m.wynn likes this.
  14. Mandylynn
    Ohio
    Awesome
    Awesome. Thanks. I am in Akron Ohio, so anyone having any suggestions as to a good independent mechanic in my area, would be awesome! :)
  15. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    A quick google search brings up Christopher’s in Tallmadge. Had good reviews :).
    Might be worth a call before they close today for the weekend(y).
    m.wynn and Mandylynn like this.
  16. Mandylynn
    Ohio
    Thanks so much! :) May just try to force my husband to do it! Looks like lots of youtube videos.
  17. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Sulphur smell comes from unburned fuel accumulating in the catalytic converter. Get on the freeway and put the car in power mode and floor it. Accelerate from 55-75 and repeat. It is also known as the italian tune up. Driving the car in eco mode, short trips, too slow, too low of rpm can cause this sulphur smell.
    Cleaning the egr and intake manifold would also be great. An oil catch can wouldn't hurt either;)
    m.wynn likes this.
  18. m.wynn
    684
    1,230
    Queensbury, NY
    **apologies, for whatever reason I'm not able to post my links to amazon for the pipe brushes and E8 socket. I'll try again in the morning in case it's a priuschat issue..Meanwhile, you can plug the descriptions into an Amazon search for proper links**
    It's not technically difficult, just an exercise in tediousness. If he did the plugs he can do the EGR circuit cleaning, and will get another opportunity to pull the wiper cowl:D. He should plan ~6 hours or so minimum to avoid having to rush.
    I have a set of aquarium-style pipe cleaner brushes that make cleaning the 2 different size EGR ports of the intake manifold quick and thorough:
    JBtek 10 Piece Nylon Brushes for Drinking Straws, Glasses, Keyboards, Jewelry
    Then 3 or 4 cans of Brakleen red can for attacking the EGR cooler and Oxiclean if you're going for the like-new finish.
    The most important tool, an E8, external torx socket in 3/8 drive for the valve/cooler studs:
    DEWALT 3/8" E8 Extension TORX Socket
    A gallon of Toy Super Long Life coolant to top up or 2 gallons if the car is due for it's full, 100k engine coolant change. All gaskets can be re-used but only total in the neighborhood of $35 or so if you want to go the type-A route. Credit to Ray for the tidy gasket part # pdf(y):
    file:///G:/Mike/car%20tech/gen%203%20prius/engine/124568_Intake_Manifold_Gasket_Item_List.pdf
    #18 m.wynn, Jun 15, 2018
    Raytheeagle and danlatu like this.
  19. Mendel Leisk
    42,379
    You can completely avoid coolant loss when removing the EGR cooler:
    Drain about 2 liters at the radiator drain spigot before starting, into a clean catch bucket of some sort, preferably with 2 liters marked. This drops the coolant level below the cooler. When the cooler coolant hoses are disconnected, there will be no spillage.
    Then, when lifting out the cooler keep it in the as-installed orientation, then tip it out over that catch bucket. There'll be maybe a half cup of coolant trapped in the back corner, that couldn't drain.
    Then when done, just pour the drained coolant back into the reservoir. 2011 Prius still have the coolant vent spigot at the top: when pouring the coolant back into reservoir leave that vent open, until coolant rises up enough to flow out, then shut it. Burbing the coolant hoses a bit as you're pouring helps, I think.
    Level in reservoir may be a little high, but should return to normal with day or two of driving.
    Raytheeagle, danlatu and m.wynn like this.
  20. padroo
    padroo Senior Member
    2,763
    2,253
    Sulpher, sounds like diesel.
