2013 Prius brake booster fail
Discussion in 'Gen 3 Prius Main Forum' started by IDs mak, Oct 19, 2021.
  1. IDs mak
    IDs mak Junior Member
    31
    Ny
    Hi forum.
    I have been driving my car with traction control light on and no issues. But today when I parked it and 30 minutes later it seems the brakes abs or booster just failed.
    I am getting a lot of codes.
    Pls see the attached pic
    Looks like abs system failed not sure where to start. IMG-20211019-WA0006.jpg
    #1 IDs mak, Oct 19, 2021
  2. IDs mak
    31
    Ny
    When I start the car the abs, traction and brake lights are On and the car has a beep nonstop
    Brakes are 5% and paddle feels like dead
  3. ChapmanF
    19,020
    Those screenshots look like car that has been piling up one unfixed issue on top of another for years....
  4. IDs mak
    31
    Ny
    There had no light besides the traction control and the Car passed the inspection 3 weeks ago.
    May be there were issues but nothing to show for it.
  5. ChapmanF
    19,020
    There is a C1241 in there, indicating a low power supply voltage arriving at the brake ECU.
    That doesn't always mean the 12 volt battery, because the code is about the voltage arriving at the ECU up front, so wiring or connector problems are also possible.
    Nonetheless, if you have not measured the voltage of the 12 volt battery, it would be a natural place to start, especially when that code is present.
  6. Mendel Leisk
    42,345
    Just to confirm: this IS a 3rd gen (you're posted in a 3rd gen forum), or 2nd gen (per your avatar)?
  7. IDs mak
    31
    Ny
    My car is gen3 2013. I think this is my 10th Prius . IIRC
  8. IDs mak
    31
    Ny
    Tried to reset the light using a mecha I shop computer (borrowed from a friend ) and after that the car brakes are working normally. I still sense the paddle is not as responsive. So the booster or brake pump is not working. Bit I can drive the car. The brake and abs lights are on with traction control .
    Least the car is moving and I can take it to a shop.
  9. amarino
    amarino Active Member
    145
    106
    99
  10. IDs mak
    31
    Ny
    My 12 v battery measures 11.70v on battery terminals before starting the car and 14.2 vonce the car is On and motor is running or not.
  11. ChapmanF
    19,020
    In that case, the C1241 probably indicates an issue in the wiring or connectors bringing power to the brake ECU.
  12. IDs mak
    31
    Ny
    What is the brake ecu location
  13. IDs mak
    31
    Ny
    Did a recent scan as the car was driving just fine other than the brake, abs and traction light these are the active codes.
    C1203 ecm communication circuit
    C1231 steering angle sensor
    C1345 liner solenoid value offset learning undone
    See the attached l
  14. IDs mak
    31
    Ny
    It turns out the master cylinder and brakes booster was the culprit.
    Solar Blue likes this.
  15. Radiospank
    Radiospank Member
    169
    82
    well thats an expensive fix.
