2013 Prius Plug-In Replacement Battery Cost
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Andrea215, Feb 1, 2021.
  1. Andrea215
    Andrea215 Junior Member
    Brooklyn, NY
    2013 Prius Plug-in
    Hi everybody!
    I am looking at buying a 2013 Prius Plug-In with 50k miles from a private party, as I previously owned the same year & model and absolutely loved it!
    I live in Hawaii and wanted to check what the cost of a replacement battery would be here, just in case I end up need a new one in the next couple of years since the car is already 8 years old, and was told by the only Toyota dealership on island that it would cost $17,000!! I know that prices are higher here in Hawaii, but this is over $10,000 more than it would be to replace the battery for a 2013 Prius that is not a Plug-In model.
    Does anybody have experience buying a replacement battery for this car and, if so, how much did you end up paying?
    Mahalo,
    Andrea
  2. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    They're generally not failing, so you may find it hard to find someone who has paid for a new replacement traction battery. Some have been replaced with used batteries.
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I've only ever seen one report here of a PiP traction battery failing. And there was a second hand account of one failing.
    In the infinitesimal chance that your battery fails in the next couple years you'd probably need to either find one in a salvage year or just replace the car. But keep in mind, if you were in a CARB state, that battery would still have two years left on its warranty. And most last WAY beyond that.
    One caution though. I don't know if you have lived long on an island, but if you've been there a while, you know about what the salty air does. I'd open up the battery case and check for corroded wires and connectors. That's the most likely failure point when you're on an island. Rust is any car's worst enemy in that environment.
    farmecologist, Wonder and Yea Right like this.
    52,857
    i would either resign myself to driving it until the battery fails, then dumping it, or not going with a plug in.
    personally, i don't think it will fail, odds are very low.
  5. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    I echo what the others are saying. It will most likely just keep slowly losing capacity, but I doubt it will fail anytime soon. Lithium is a stable chemistry
  6. Mendel Leisk
    42,349
  7. Desertdeals69
    Desertdeals69 Junior Member
    44
    23
    Lk Havasu City Az 86403
    When I bought my 2014 plug in last year I thought I should have a back up battery because if you need one it seems like you have to pay a lot more for it. I got a 2015 with 67K miles for $625 delivered to my door. It has all 4 sections. Before that I got one section for $220.
    nesoccer and Mendel Leisk like this.
  8. Andrea215
    Brooklyn, NY
    2013 Prius Plug-in
    Thanks so much for the replies. And for those of you who had a back up battery shipped to you, was it difficult to find one? Wondering what shipping would be like to Hawaii.
  9. QuantumFireball
    420
    269
    Ireland
    It seems like a waste to bother getting a spare traction battery - Li-ion batteries have a shelf life so it will degrade regardless if it's used or not, and if it's not maintained in some way it will degrade even faster (e.g. if voltage gets too low).
    jerrymildred and Mendel Leisk like this.
  10. Mendel Leisk
    42,349
    Yeah same thought here. It's good to know there are options, but don't dive in and get a spare; just educate yourself as to how/where they can be obtained, and recheck periodically, that sources aren't drying up or whatever.
  11. bisco
    52,857
    how can all this be cheaper or easier than buying a corolla or some such
    Yea Right and Mendel Leisk like this.
  12. fos4110
    fos4110 Junior Member
    36
    Kent, WA
    2015 Prius c
    Following this thread and sounds like you have a lot of experience with the plug-in.
    I have a 2014 Prius plug-in that I bought used at 135,000 miles last February. I’m now at 209,000 miles and haven’t had any problems. I’ve had three Prius’s in the past that were not plug-in. I’ve had to replace the battery on each of these (with refurbished units).
    I’ve been told that to replace one of these plug-ins are quite expensive - much more than my previous Prius models. It seems like the thread indicates that these plug-in batteries don’t fail easily - is that your experience? Please let me know. Thanks.
    Mike
    farmecologist and bisco like this.
  13. bisco
    52,857
    that is the experience of everyone here with a pip. still no failures after 12 years and many, many miles.
    fos4110 and Mendel Leisk like this.
  14. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Hi Andrea,
    I live on Kauai and have a couple of older Priuses. Nothing Prius is cheap here.
    In your shoes I would budget for the $17k rip off, but when/if the time arises with some effort you can find cheaper ways to ship than asking a dealer to do it. And cheaper ways to fly a knowledgable competent guy out to install it. Just have a back up plan for transport while you wait, because it won't happen fast. I'd suggest buying a regular back up car from one of your friends if an opportunity arises
  15. fos4110
    36
    Kent, WA
    2015 Prius c
    awesome thanks for the heads up!
    mike
