2014 Prius C idling high, running rough
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Tiamaybe, Aug 10, 2022.
  1. Tiamaybe
    Tiamaybe Junior Member
    2014 Prius c
    I have a 2014 Prius C that was running great except for the radiator had a leak. It was quiet, smooth transfer between gas and electric, idling normal. We changed out the radiator yesterday and now the car is idling in an accelerated mode and longer before cutting off. It also now feels like there is some resistance when trying to gain speed. Sometimes when it’s idling high pushing the gas pedal does nothing at all to it. It continues at the high idle. Sometimes even goes a little higher before cutting off for electric. Any idea what this could be? I’m at my wits end with it.
    52,855
    how many miles on her?
    any trouble lights?
  3. Tiamaybe
    2014 Prius c
    No trouble lights or codes. About 147k
    52,855
    i would run a battery health check with dr. prius app, and do a load test on the 12 volt.
    did you bleed all the air out of the coolant loop?
  5. Tiamaybe
    2014 Prius c
    The 12v battery is brand new. Just replaced it about a week and a half ago. I believe we did. Filled it, started it, let it drop, topped it off, drove around the block, topped it off. Then drove home (about 3.5 miles) the inverter tank and reservoir tank were still full. Topped off the radiator this morning after it was cool. It drove home fine last night. Then after typing her off this morning and leaving is when it did it for the first time.
  6. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    That brief description usually points to a vacuum leak. Pull codes man
  7. Tiamaybe
    2014 Prius c
    Pull codes what? It is not throwing any codes. I’ve already had that checked.
  8. douglasjre
    2,250
    751
    Null, NL
    check short term fuel trim. You need the computer
  9. douglasjre
    2,250
    751
    Null, NL
    Pending Codes. no MIL doesn't mean there's no data.....
  10. douglasjre
    2,250
    751
    Null, NL
    Who checked for codes? AutoZone? Skip that $5 scanner. You need the dealer computer. If you're not a mechanic this tak is going to be over your head. Save your time and all the frustration you'll go through. Send it to the dealer and be done with it.
  11. vrej sarkissian
    vrej sarkissian Junior Member
    I
    did you figure out what's causing the rough idle?
    mine is doing the same thing and getting worse by the day
