2015 Prius C - P261B code
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Ayoubmark, Aug 18, 2026 at 10:37 AM.
  1. Ayoubmark
    Ayoubmark New Member
    Yesterday
    2015 Prius c
    Hello,
    My 2015 Prius C (in Canada) shows the check engine light. The OBD reader says : P261B engine coolant pump b control malfunction.
    The check engine light has been there on and off (2 days on 1 day off, sometimes 3 days off) for more than 8 months now, and I've been using the car with no issues. Only thing is that 4 months ago, I got a Check Hybrid System warning while I was driving. I immediately stopped the car, unplugged the battery box in the front, waited 2 minutes, plugged it back and drove off. No issues since, but always the check engine light on and off.
    Last week, the "Check Hybrid System. Stop the vehicule in a safe place immedistely" came up while I was driving. I continued to drive looking for a spot to stop as I was on a main way. I felt that the accelerator is not working, the car is just losing speed. The car stopped I was lucky enough to stop on the side of the road. I did the same thing as before (unplug the battery box, waited 1 minute, then plugged it). I drove off with no issues. Next day, the same Check Hybrid System message came up and again the car stopped on its own.
    I used my OBD looking for any codes but nothing except the P261B fault code. I used the Dr. Prius App to do a Hybrid battery test, it gave me 77 % battery health. While doing the code reading, I erased the codes through the Dr. Prius App (I already did that few times in the past).
    The next day, I took the car to a mechanic nearby and told him that it needs a coolant pump replacement. He said they need to make their own diagnostics before replacing anything. I left the car in the garage. 2 hours later, the garage called me saying that they did their diagnostics but they could not find any fault codes on the car and that it is working well, except that the 12 V battery needs replacement (an issue that I noticed recently). I went to meet the mechanic and I showed him the fault code I get each time I use my OBD reader. He said that we should then replace the coolant pump. I asked him for an estimate, he said its around 1200 CAD for the pump and the battery replacement all included.
    I took the car back and I used my OBD reader looking for the fault code, but NOTHING shows up. I even used another OBD App and it also did not detect any codes. I know that even when I erase the codes through any App, the code still remains, but this time the P261B code just disappeared.
    2 days later, the check engine light came back. I used my OBD reader and it showed the P261B code.
    Now I'm wondering, is the P261B code actually linked to the "Check Hybrid System. Stop the vehicule in a safe place immedistely" warning I got??. I also wonder how come that the code disappeared from the car for few days and did not even show up on the advanced diagnostic tool of the mechanic??
    Also, looking back at the code being there for so long with no real impact on the car, does the pump really need to be replaced, or is it just a sensor/wiring issue that needs to be fixed??
    Any comments will be appreciated.
  2. ChapmanF
    19,052
    Here's how that linkage works:
    1. The engine control module detects that the water pump is not pumping water. Sets the P261B code and lights the check-engine light.
    2. Because the lack of coolant circulation puts the engine at severe risk of overheat damage, the engine control module activates a special new rule: normally, a coolant temperature of 105℃ is no big deal and nothing special happens at that temp (it's still well below the 120℃ threshold where the red overheat light would come on). But under the special rule when the water pump is b0rked, the ECM will cut the engine right off if it reaches 105℃, with no further warning or notice to anyone.
    3. If that happens and the engine cuts off, the car has very little power, just electric motor and the battery, barely enough to kind of crawl the car at city-street speeds for maybe a block or two.
    4. The power management control ECU (which is like the orchestra conductor for the car) doesn't know why the engine cut out. (Remember the ECM does that at 105℃ immediately and without giving any notice.) But the power management control ECU can definitely notice that the engine has cut out. So it sets its own trouble code, P0A0F ("hey! how come the engine has cut out?") and gives you the hybrid system problem, park immediately message.
    It's possible for the pump to be flaky, and function intermittently. If the code goes away, it can stay away until the next time the mismatched-RPM condition is actually detected.
    It would be a mistake to think of running the engine without coolant circulation as having "no real impact on the car".
    Ayoubmark likes this.
  3. Ayoubmark
    Yesterday
    2015 Prius c
    @ChapmanF, Thank you for your explanation and advice. Much appreciated!
