2015 Prius Plug In "Check Hybrid System"
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by TrinaF., Oct 10, 2014.
  1. TrinaF.
    TrinaF. Junior Member
    74
    24
    Southern California
    That was exactly it, Rebound. The "Check Hybrid System" indication never went off. I drove it over the weekend after it started. I know I can most likely drive it. The service tech said something about the way it works with the software. Whatever. They're trying to take care of it.
    And we're giving it 30 days. Once that's up, we will most likely start the process of asking for a refund pursuant to Lemon Law. It's only been a week so far, so we're just waiting......
    Will let you know when/if anything happens.
    j12piprius likes this.
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    That's different. If the Check Hybrid System light won't go off, it needs to be fixed. I thought you just meant that you can't charge the car.
    They really should get you a loaner vehicle and repair your brand new car. Very surprised at them if they aren't.
  3. TrinaF.
    74
    24
    Southern California
    I was provided a Corolla, which I turned in the first day and paid above and beyond for a more comfortable car. I do a lot of driving, and the Corolla was uncomfortable for me. So I forked out the extra $20 daily for a BMW. Whatever, I'm over it.
    I received the call just now that the part came in and has been replaced and I should be able to pick up my car tonight. Wish me luck!
    52,877
    good luck!(y) can't wait for details!:cautious:
  5. GaryD06
    GaryD06 New Member
    Belmont, CA
    2015 Prius Plug-in
    Have a one month old 2015 with less than 1,000 miles on it. Got the same hybrid system problem described above. Followed the instruction not to drive the car and had it towed to the dealership. Dealership says the hybrid charging system needs to be replaced and there's a two week backorder on the parts needed. Now driving a lovely Nissan Versa loaner car.
    Hope I didn't make a bad decision going with this plug in.
  6. bisco
    52,877
    nah, you'll be fine. just a spate of bad chargers for some reason. must have a bad sub part or something. you think it would get caught in testing though.
  7. TrinaF.
    74
    24
    Southern California
    Car is driving fine so far. I'll report back after driving it a bit.
    vvillovv likes this.
  8. bisco
    52,877
    excellent!;)
  9. Rebound
    3,996
    2,645
    Portland, OR
    Awesome! If it's a typical Prius, you'll need little more than oil changes for the next 100,000 miles or more.
  10. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    What did they end up doing?
  11. bisco
    52,877
    replaced the charger. it's in another thread.
  12. TrinaF.
    74
    24
    Southern California
    Yes, replaced the charger. So far, so good.
  13. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    seems there is a bit of confusion concerning this issue.
    the link provided states that some cars save the ODB2 data to non-volatile memory.
    And if Prius is one of those I think it would be good to know what data is saved and what data is lost.
    Here is another post that states a dealer doesn't recommend disconnecting the 12v due to data loss.
    Parking My Prius v for a Few Weeks | PriusChat
    Personally, I'd want to know before messin with the 12v, even if disconnecting it only eliminates the trip data.
    But I sure wouldn't want to erase any freeze data, if codes have been set and the Triangle indicator is on.
    TrinaF. I'm glad you finally got your car back it's OK
  14. bisco
    52,877
    if that were the case, there would be a lot more problems due to dead batteries than just the car not starting. unfortunately, there are a lot of clueless dealers.
