2017 Prime Antenna Removal
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by xvs, Feb 28, 2021.
  1. xvs
    xvs Member
    88
    30
    san francisco
    Are there any instructions online, or does anyone happen to know, how to remove and replace a 2017 Prius Prime rooftop antenna?
    I see a small screw on top and think that may be what holds it on, but so far I haven't had the right tool to get enough torque to unscrew it -- its very small and very tight. Is this what I need to remove, or does it come off in another way?
    Thanks for any help.
  2. Prius7Prime
    Prius7Prime Junior Member
    58
    Long Beach
    2012 Prius Alpha
    your manual might have info? if not then im sure its a simple process. i have no experience with it but if you google "prius prime rooftop antenna removal" you will get some hits for sure. sorry about the issue.
