2017 Prius 3 Touring Homelink Upgrade?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by VictorBravo, Jun 1, 2017.
  1. VictorBravo
    VictorBravo New Member
    Los Angeles
    Three Touring
    With all my research on the forum/web I can't seem to find any success stories of owners installing the OEM Homelink mirror to a 2017 Prius Touring 3 with Toyota Safety Senseā„¢(TSS). With all those electronics behind the OEM mirror there is obviously power up there so it should be possible, right?
    Here is the 2016 OEM mirror I am considering: not a direct link :)
    "shop.priuschat.com/auto-dimming-mirror-with-homelink-2016-toyota-prius"
    If anyone has any insight to why this would or wouldn't work, please respond. thank you!
  2. XnsmX
    XnsmX Junior Member
    Los Angeles
    Please read up on this thread:
    Adding Homelink mirror | PriusChat
    Also there is a review in link you posted "Does not fit 2016 three with sunroof and ATP." It's probably doesn't fit because of all the electronics up there.
  3. VictorBravo
    Los Angeles
    Three Touring
    Thank you. I read this as well and the main issue I believe is finding the correct HomeLink mirror that has a long enough neck on it to not interfere with the TSS plastic cover. I called the dealer and they wanted 700$ for the OEM mirror. Not happening. 200$ sure. I don't have a sunroof but I do have the TSS. I prefer OEM but not at that price!
    This is the mirror I need to find for the right price. Compatible with the TSS.
  4. Adam1a
    Adam1a Member
    50
    59
    Three Touring
    You just need the right extension to mount the mirror. This may help.
