2017 Prius prime. Snow/ice buildup
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by muleman, Jan 31, 2018.
  1. muleman
    muleman Junior Member
    56
    49
    rochester ny
    Ok kind of a PITA and I hope the back glass doesn't snap. I keep getting ice buildup under the top of the hatch. So it will bind up and my hatch will crush the ice and stop the hatch from opening. Sucks as I keep my charger cable back there 1517457238432.jpg
    52,773
    sounds bad, maybe try spraying it with some sort of ice melter?
  3. Trollbait
    12,804
    I just had this happen on the Camry, but not enough to prevent opening of the trunk. On past hatchbacks, it would require a lot of ice to prevent opening; plenty of empty space in that area.
    A 35% to 45% solution of rubbing alcohol can be used as a de-icer. Let fresh solutions chill to outside temps before using; it won't freeze.
  4. muleman
    56
    49
    rochester ny
    I tried twice to load the image from my phone. Not sure why it failed, it worked before. I might try some adhesive door weather striping and see if i can block the space a bit.
  5. muleman
    56
    49
    rochester ny
    I tried uploading the image and its too big. I think de-icer would be fine to fix the problem. But I need to prevent it. I don't want to de-ice it every-time it snows. It has happened about 6 times in 4 weeks. I might try some rubber weather striping.
    Trollbait likes this.
  6. muleman
    56
    49
    rochester ny
    I cropped it to reduce the size =)
  7. bisco
    52,773
    some type of small magnetic cover would be perfect.
  8. Mendel Leisk
    42,254
    Is this where you're getting the ice?
    muleman likes this.
  9. Trollbait
    12,804
    The weather stripping is a good idea.
    Does the gap appear a normal size, or larger than on metal skinned cars? The plastic panels of Saturns would expand and contract more than metal, and I was wondering if this true of the carbon fiber hatch. I can't tell from the photo.
    Rolls of magnetic tape is sold for craft projects. This would be easier to try than weatherstripping. If the roof is steel.
  10. bisco
    52,773
    oh yeah, the hatch is plastic fiber, or carbon plastic or something.
  11. muleman
    56
    49
    rochester ny
    yes this is were it is building up.
    Hatch is carbon fiber and glass.
    I ordered some weather stripping I am going to install on the inside edge and see if it will keep out the snow and ice.
  12. muleman
    56
    49
    rochester ny
  13. bisco
    52,773
    that looks custom, good luck!
    muleman likes this.
  14. NHPrime
    NHPrime Junior Member
    23
    Andover MA
    2020 Prius Prime
    I used to get have this problem on my Honda Fit as well. I'm sure the metal is strong enough that it's not causing any damage, but the crunching sound from the snow/ice compressing was certainly unnerving! How did the weather stripping work out for you?
    #14 NHPrime, Feb 16, 2019
  15. DavidA
    2,349
    1,825
    Chicago western burbs
    If the ice build-up was adjacent to metal on both sides then the crunching when opening would be less of a worry. But the glass covers the hatch up there. I've worried about this too up here in Chicago. Ice build up around the hatch has been constant for 25 straight days now.
  16. Tideland Prius
    16,668
    The gaps are bigger on the Prime and I assume it was due to the CFRP hatch.
