2018 Prime making high squealing noise from the dashboard area
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Sleepyshi, Oct 10, 2021.
  1. Sleepyshi
    Sleepyshi New Member
    San diego
    2018 Prius Prime
    Hello,
    My 2018 Prius Prime plug is starting to make intermittent semi high-loud squealing/whining sounds coming from the dashboard (more towards passenger side).
    I noticed this sound
    - will occur regardless of whether the car is driving or not
    - will occur whether AC is on or off
    - more noticeable when I’m turning the wheels or braking, but still occurs when driving on in a straight direction.
    I DID notice that this sound when I was sitting in the car after turning it off. This sound happened simultaneously when the engine is doing one of it’s “powering down” arrangement of noises, which lead me to believe it is related to the system.
    I wanted to ask on here to see if anybody has come across this issue before taking it to the dealership to get it checked.
  2. ChapmanF
    18,995
    Are you able to post a recording?
    52,807
    how many miles on her?
  4. Sleepyshi
    San diego
    2018 Prius Prime
    I’ll get the recording over next week. Op’s membership with Priuschat is still new.
    Around 70,000 miles right now
    #4 Sleepyshi, Oct 10, 2021
  5. Sleepyshi
    San diego
    2018 Prius Prime
    Here’s the link to the sound
  6. ChapmanF
    18,995
    What a weird sound. You mentioned it "will occur whether AC is on or off"—can I assume you also tested with whether the climate control fan is on or off?
    jerrymildred likes this.
  7. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Was your audio on? Because you said the sound came out even after the car after turning it off, it is not likely to be audio. But still, I wanted to ask.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    That is an odd sound. I think I'd be wondering about the hvac air flow control doors. As Chap asked, is the AC off or is the whole ventilation system off?
  9. Sleepyshi
    San diego
    2018 Prius Prime
    yes, the AC was off during the time when one of the intermittent noise was happening (power button was pressed off during one of these times)
  10. Sleepyshi
    San diego
    2018 Prius Prime
    definitely not the audio. When this sound comes on, I would turn off the stereo and it would continue making that noise. Therefore it would happen regardless if the stereo was playing or not
    Salamander_King likes this.
  11. Sleepyshi
    San diego
    2018 Prius Prime
    i can try again with the climate control fan off to see if the noise continues. I will keep the thread posted.
  12. Salamander_King
    11,024
    8,978
    New England
    Yeah, if the AC is off but HVAC is still on, then the fan might be still spinning. That would be the most likely cause. If HVAC is completely off, and still makes this sound... then we will be back to the drawing board.
  13. Sleepyshi
    San diego
    2018 Prius Prime
    After driving around for a couple days, it might be the fan, like you mentioned.
    There are a couple of times when the sound starts up, I would turn off the fan and the sound will “abruptly” squeak and stop a second after pressing the off fan button.
    I also notice that the sound does not come on if I keep the fan off for a period of time.
    I haven’t been driving as much these last few days so the sound isn’t happening as often or as loud as the video I posted. But I was able to test it when the sound is in action.
    jerrymildred and Salamander_King like this.
