2018 Prius completely dead even after jumping. What now?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Halcykon, Apr 15, 2020.
  1. P_Aug
    P_Aug New Member
    Arizona, United States
    2018 Prius
    Two Eco
    Hi all! I am new here, and rather than starting a new thread, I was wondering if you could give me some advice here. We have a Prius 2018 (Two Eco) and we just bought a charger (Noco genius 2). But before using it, we had to figure out what type of battery we have, because the charger requires that we specify if we will be charging a regular or an agm battery. We called the dealership and they said that the 12v battery in our car (which has never been replaced since we bought it) is AGM. But, I keep seeing discussions (in this and other forums) referring to gen 4 prius battery as a regular wet lead-acid battery. I am attaching a photo of the battery and I was wondering if anyone could help me figure out what type of battery this is. Is this how an agm battery would look like? WhatsApp Image 2020-10-13 at 9.08.26 AM.jpeg
  2. Mendel Leisk
    42,373
    It's not an AGM. The charger will likely do a rudimentary assessment of the battery before commencing the charge program. If it refuses to start, it's a fairly safe bet you should replace. Electronic load testers could confirm; battery retailers typically have such testers and will usually test for free.
    RojaRosie, krmcg and P_Aug like this.
  3. Mendel Leisk
    42,373
    There's some info here about compatible batteries.
    @Elektroingenieur is on top of it. He may have even linked in this thread, but between my limited brain cells and dated phone, all I can do is invoke his "bat signal".
  4. P_Aug
    P_Aug New Member
    2018 Prius
    Two Eco
    Thank you for the clarification, @mendel-leisk.69191 I really appreciate it!!! This is really helpful.
  5. Elektroingenieur
    2,515
    3,288
    Three Touring
    The battery in your photo looks just like the one in my car, which is definitely a “maintenance free” flooded (wet) type, not an AGM battery, as @Mendel Leisk kindly mentioned. The dealer may have been confused because 2015 and older Prius cars, and Prius c and Prius v models, do use AGM batteries.
    See my September 20 posting.
    For bats, I recommend the Congress Avenue bridge.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    AGMs wouldn't have the filler caps.
  7. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    I realize that this post is a bit old, but I like answering things that might show up in Google. :)
    Mice, when they get into a car (because it is a nice shelter), seem to be attracted to wiring, frequently chewing on it. They like to make nests out of the air filter material (as well as other insulation), and the air filter boxes make fantastic nests, by mouse standards.
