2018 Prius Four - cons
Discussion in 'Gen 4 Prius Main Forum' started by LilyT, Jan 26, 2018.
Tags:
  1. LilyT
    LilyT Junior Member
    Seattle WA
    2018 Prius
    @alanclarkeau Correction: turning on the headlamp does illuminate all the buttons on driver side door (I haven't checked other doors) and the buttons around the big screen, it doesn't help on the garage door opener buttons though.
    In my previous reply, I mentioned that I had to reply on finger to locate the unlock door button on the driver side door. Here is the scenario behind it. I need to pick up my son after school around 6pm. I arrive at the parking lot a couple minutes ahead of time, shut down the engine, turn off the headlamp, sit and wait in the dark. When I see him coming out of the building, I turn on the dome light and search for the button to unlock the door. Unfortunately, the dome light is dim & narrow, and the turning wheel is in its the way, further blocking the light from illuminating the door buttons. I have to use my finger to feel which one to press.
    My old driving habit is to start the engine first, turn on headlamps, switch the gear, then go. If I had changed the order so that I turned on headlamps first, then I would have noticed the door buttons got illuminated.
    Well, I need to grow new driving habits with the new car.
    RCO likes this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I carry a small led pencil torch, but haven't had cause to use it yet and mine had black fabric upholstery.
  3. Diemaster
    Diemaster Active Member
    301
    264
    so. cal
    i got some of these led bulbs from superbrightleds.com for the front dome light. there the brightest 194 bulb they sell. get the warm white as it's kelven temp (how red or blue the light is) is very close to a filament bulb.
    this one is a good matching warm white for the rear dome light.
    CoolPrius and RCO like this.
  4. Mendel Leisk
    42,343
    Our third gen's like that too. I can recall, we were picking someone up at night, and all the doors were locked (auto-locked I guess), so I'm looking down at the arm rest, trying to discern the lock/unlock switch, good luck with that! There was one little point of light, which I determined later was in the middle of the lock side (iirc) of the lock/unlock rocker switch, nada on the window switches. They really all should be backlighted, but nope.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    What about using the reading lamp(s)?
    Alternatively, press POWER and your Auto headlights would come on, and the buttons will then light up.
    RCO likes this.
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    They implied the buttons on the mirror do not light up. My car is too basic to have that feature so I cannot verify that.
    #26 Prodigyplace, Jan 28, 2018
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Thought you had dogs? :sneaky:
    kithmo, Prodigyplace and alanclarkeau like this.
  8. alanclarkeau
    7,045
    7,593
    I don't have a CAT - but my dogs have headlights
    Back to PRIUS - with my PRIUS - I tried it, when I drove into my carport (but I don't have a Garage Door, or a Garage Door Opener), I POWERED OFF, and sat in the car. After 5 mins I got bored, because nothing changed.
    My headlights and taillights were still on, 53 back-lit indicator lights were on on the armrests, dashboard and overhead lamp display. BUT - there were NO lights on my mirror - but mine only has one button "AUTO" for auto-dim, and it wasn't back-lit. There was one red light flashing occasionally on the dashboard - the IMMOBILISER SECURITY INDICATOR LAMP: upload_2018-1-28_21-51-51.png
    So, sorry, I'm not sure, I think mine might be too different from yours.
    You could ask your dealer - they might be able to advise or check another car.
    Prodigyplace and RCO like this.
  9. Prodigyplace
    12,712
    11,848
    Central Virginia
    LOL - corrected my typo (Phone auto-correct?)
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Gee. Never heard of that problem myself! :sneaky::ROFLMAO:
    kithmo and Prodigyplace like this.
  11. Prodigyplace
    12,712
    11,848
    Central Virginia
    kithmo and alanclarkeau like this.
  12. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Didn't I say it was futuristic in another thread? Well spotted Hawkeye!
    alanclarkeau and Prodigyplace like this.
  13. Mendel Leisk
    42,343
    3rd gen homelink buttons don't light, we're only using the left end button, I find it by braille method. Actually even in day light, it's too distracting to be looking up, trying to find diminutive button visually, day or night.
    And yeah, the driver's side armrest buttons, door look and windows up/down, are all dark (with headlights on), apart from one DOT of light on the lock side of the door lock/unlock rocker switch.
    How do 4th gen drive'rs door buttons compare, do they light with headlights on?
    RCO likes this.
  14. Prodigyplace
    12,712
    11,848
    Central Virginia
    They lettering is backlit, just like the dash buttons around the MFD and the steering wheel buttons.
    kithmo and Mendel Leisk like this.
  15. alanclarkeau
    7,045
    7,593
    The overhead ones are:
    As are the door:
    kithmo, RCO and Prodigyplace like this.
  16. Mendel Leisk
    42,343
    I wonder if I have some lights burnt out? Or maybe flakey memory? Or I had the lights off. I'll check.
    kithmo, RCO and alanclarkeau like this.
  17. Mendel Leisk
    42,343
    Ok I kind of lied: there is a light bar on each window switch, and a single dot of light on the door lock rocker. The latter is not that helpful though; 4th Gen is an improvement.
  18. Tideland Prius
    16,680
    Yeah, the Gen 3 was the first Prius with illuminated buttons (yay!). Power window switches and the driver's side door lock (yeah, that dot in Mendel's picture is the LOCK side of the power door lock. It's a raised dome, while the unlock side is a depressed dome).
    Gen 3.5 (i.e.2012-2015) brought illuminated mirror controls.
    Gen 4 obviously stepped it up with full illumination of the mirror and door lock controls as well as an illuminated window lock and overhead switches. (Gen 3 had no illuminated for the overhead lights but the sliding knob was easy to find)
  19. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    You really should check your phrases for ambiguities. ;):whistle:
    Mendel Leisk and alanclarkeau like this.
  20. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Takes one to know one, they say.... :sneaky:
