2019 Prius Limited Fog / Daytime Running Lights
Discussion in 'Gen 4 Prius Accessories and Modifications' started by TractionAction, Mar 10, 2020.
  1. TractionAction
    TractionAction Junior Member
    Brentwood CA
    2024 Prius
    Greetings,
    I'm looking for some ideas on installing a fog lights or (accent) daytime running lights in the front plastic bezel on each side of the car. I tried Toyota and they don't seem to have any, I do see them as options on 2020 models. I've seen this done on a 2017 Prius off this forum, but not for the Prius Limited.
    Any help will be appreciated!
  2. krmcg
    2,592
    2,391
    Whittier, CA
    I purchased a set of used OEM fog lamps from Japan. (they looked like new) and had them installed at my house by a very experienced local technician. Loved the purchase and the upgrade. They work on the existing steering wheel lighting stalk.
  3. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    I am interested in this too. Right now, the selection of kits seem to be very limited. Hopefully a wider variety kits that fit the front bezel will become available with time.
  4. TractionAction
    Brentwood CA
    2024 Prius
    And that's why they call it "Limited" ice9!
    Nice krmcg, can you share any photos?
    ice9 likes this.
  5. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    o_OI don't why, but somehow I completely missed that!
  6. krmcg
    2,592
    2,391
    Whittier, CA
    They are OEM. Same as the touring models had factory installed.
    ice9 likes this.
  7. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    If I remember correctly the OEM kit uses a modular assy. By any chance did you look it to see if it is possible to change the led/bulb?
  8. krmcg
    2,592
    2,391
    Whittier, CA
    No I didn't. I inspected the lights for quality and damage, but did not do any investigation.
  9. Tideland Prius
    16,443
    #9 Tideland Prius, Mar 11, 2020
  10. Mylar
    Mylar Member
    163
    36
    Cincinnati, OH
    2019 Prius
    I've got a 2019 Toyota Prius Limited and I just ordered the following parts:
    LED Side Lights: 812B047020, 812A047020
    Housing Inserts: 5271347060, 5271247060
    Wire Harness: 8193547060 Qty 2.
    Is this all I need for these lights to operate? Local Toyota dealership doesn't seem to know.
    Thanks,
    Mylar
  11. TractionAction
    Brentwood CA
    2024 Prius
    Yes, those are the parts I bought. Install a little tricky tho getting into tight spots. They look great after.
    Mylar likes this.
  12. Mylar
    Mylar Member
    163
    36
    Cincinnati, OH
    2019 Prius
    I went ahead and installed BOTH the clearance lights and the fog lights today. I removed the bumper cover to make the job easier. Here are some pics of the job. I still need to buy the steering wheel switch, so for now, the fog lights are inop.
    angelnvrgod likes this.
  13. Mylar
    Mylar Member
    163
    36
    Cincinnati, OH
    2019 Prius
    I installed the OEM steering wheel light switch with Fog Lights. When I turn the headlights to on and the fog lights on, I get indication on the dash, but still no fog lights. Is there a part of the wire harness under the dash that needs to be connected for the fog lights to work? Looking for a little advice. Thanks!
  14. angelnvrgod
    angelnvrgod New Member
    portland
    2022 Prius
    L Eco
    did you ever figure out the problem? Im planning on installing mine this weekend. Did you add your own wire harness or (wishful thinking) was there a harness already there?
  15. Robert21PrimeLTD
    72
    36
    Nashville
    FYI, my 2021 Limited came with LED Fog & Accent Lights. This is how they look.
