2019 Prius Prime Advanced - Front Grille Replacement
Discussion in 'Prime Main Forum (2017-2022)' started by Pedro Castillo, Jun 19, 2019.
  1. Pedro Castillo
    Pedro Castillo New Member
    San Bruno, Ca
    2019 Prius Prime
    Hello,
    I recently upgraded my Prius Prime Premium to a Prius Prime Advance, and I am loving it with all of the extra features you get with this package. Unfortunately, a week after I bought someone hit my front grille and put a hole in it.
    I can submit it to my insurance, but my deductible is 1000.00 more than it would cost to repair it. So I have decided to do it myself, but unfortunately, I have not found proper details instructions to go through the entire process of replacing it, the Toyota website where I bought the Grille does have instructions but after following them it appears there are more components that need to be removed such as the headlights, etc. before removing the Grille.
    Also, I have looked on YouTube videos but no luck as the only videos I was able to find where for the regular Prius, does anybody know where I can get complete instructions of what needs to be taken apart so I can proceed with the replacement?
    Thanks in advance,
    52,849
    welcome!
    techinfo.toyota.com
  3. Washingtonian
    Washingtonian Senior Member
    726
    621
    Welcome to the forum, Pedro. I have a suggestion that doesn't concern your car. You probably should change your avatar to remove your home address. Just a city and state is more than enough.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
  5. Pedro Castillo
    San Bruno, Ca
    2019 Prius Prime
    Thank you very much for the link Salamander_king, I will have a friend translate the document for me.
    Salamander_King likes this.
  6. Pedro Castillo
    San Bruno, Ca
    2019 Prius Prime
    Completed the job over the weekend, saved me $400 quoted by my local body shop.
    Thanks, again Salamander_king
    Pdxprimeguy and Salamander_King like this.
  7. Salamander_King
    11,024
    8,978
    New England
    Did you ended up replacing entire grill sub-assembly (part #53101 in the diagram both acrylic fascia and black grill together)? Or could you just replace the acrylic part of the grill sub-assembly (shown in the diagram below with the orange arrow)? I have a crack on the acrylic fascia just like yours, but since you can't buy just the acrylic part separately, I have not touched it yet.
    #7 Salamander_King, Jun 24, 2019
  8. roypaik
    roypaik Member
    161
    39
    Orange County
    2020 Prius Prime
    I have the same question.
    @pedrocastillo how was the install?
  9. Salamander_King
    11,024
    8,978
    New England
    I'm afraid @Pedro Castillo is no longer here.:(
  10. bevhoward
    bevhoward Member
    64
    32
    Austin, Texas
    2020 Prius Prime
    on my 2020 prius prime, it was necessary to remove the entire front bumper, grill, fenders etc per this video even though the video is for an older prius. Pretty sure that there is no way to replace the grill without doing so.
  11. Mendel Leisk
    42,343
    @jerrymildred was trying to separate the smoked transparent plastic portion but found it bonded iirc. Maybe has some tips, link.
    Danny13pruisc3 likes this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    See post #599 on this page. Jerry's Evolving Thoughts on "new-to-me" Prime Premium | Page 30 | PriusChat
  13. Chris Black
    Chris Black Junior Member
    31
    Arlington, va
    I posted my own thread before I found this one. My grille too got hit by a rock and has a 'spider web' mark now. I watched a few videos about repairing acrylic in general as well as acrylic headlights in particular. I am seriously considering sanding down the the mark, putting on clear coat, and then wrapping the acrylic part in a protective clear film.
    My Wife offered to try with her acrylic clear nail polish, but I have my doubts if its up to specs for wind and rain over years...
  14. Mendel Leisk
    42,343
    Can't recall if I mentioned in this thread: there's a process for repairing and stabilizing small "stars" on windshields. Novus was on name that comes to mind. Might work on plexiglass, not sure.
  15. Salamander_King
    11,024
    8,978
    New England
    If you do try to repair the crack DIY, it is very important that you do take off the grille sub-assembly parts off from the car. It must be sitting flat on the workbench. Trying to repair it on the car without removing the grille will cause the liquid solvent to run down and cause more of cosmetic damages on the surface of the acrylic. I did it on my 2017 PRIME with superglue. The result was, just say, very unsatisfactory.
    I am still waiting for the WeldOn (commercial acrylic solvent) I ordered from Amazon. When I get it, I will try repairing recently purchased used (cracked) grille sub-assembly parts shown in the photo below. I will let you know how the repair goes. My plan is to repair all the cracks first with WeldOn then reinforce the cracked acrylic portion with epoxy on the back side and finally paint or wrap it in non-transparent color. I have checked with a local Line-X service center to see if it can be coated with material used for the truck bed liner. But they quoted me $200 for the job, which is too much for what I want to spend on this project. The cracks are going to happen again no matter how well it is fixed. If the surface of the clear acrylic is covered with non-transparent paint or wrap, then any future cracks are going to be much less visible thus cosmetically acceptable, I think.
    #15 Salamander_King, Aug 21, 2020
    Chris Black and jerrymildred like this.
  16. Trollbait
    12,825
    As I understand it, the 'glue'(I think most use an UV setting cement) is applied under pressure in order to force it into the cracks. A hole might need to be drilled to allow the glue fully in.
    Acrylic cements come in different viscosities. Liquid ones, like @Salamander_King will use, are known as wickable; capillary action pulls the cement into the crack. Such are used by DIYers for making acrylic aquariums.
    Apiece of metal screen embedded in the epoxy will give it more strength. Not knowing what type of epoxy you are using, you want a screen size that the epoxy can fully penetrate.
    Mendel Leisk and Salamander_King like this.
  17. Salamander_King
    11,024
    8,978
    New England
    I have J-B Weld Original Steel Reinforced Cold Weld as well as regular multipurpose J-B Weld ClearWeld epoxy, but also ordered J-B Weld 50139 PlasticBonder. According to J-B Weld site, the Original ColdWeld has 5050PSI tensile strength and ClearWeld has 3900PSI tensile strength whereas the PlasticBonder has 3770PSI tensile strength when cured. I may try using some wire screen if I can find suitable one in my garage or I may use old Bondo fiberglass tape I used for previous auto body repair project.
    But my feeling is that if I am going to reinforce entire back side of the acrylic panel, adding screen maybe a good idea. But I am thinking applying the epoxy only to the part that had cracks. In that case, an additional strength may not help much. If the rock hit the panel again it will just crack the part that is not strengthened. Covering entire back side of the panel may take way too much material, again that will ends up costing too much.
    #17 Salamander_King, Aug 21, 2020
  18. Chris Black
    31
    Arlington, va
    keep us posted on the process. I will try to buff the cracks first and see if there is any difference
    But will try to remove the bumper if I need to do additional work
    Thanks
  19. RonanOD
    RonanOD New Member
    Nova Scotia, Canada
    2018 Prius Prime
    Upgrade
    Hi. I'm hoping to fix a tear on my front bumper for my 2018 Prius Prime. I translated the Japanese PDF above to help me with the process.
    DD1, pghyndman and Mendel Leisk like this.
