2021 Prime Cold Start Rattle - Gen3 Prius Bad!
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by cawlin, Aug 29, 2024.
  1. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    Similar problem = Cold start rattle.
  2. Mendel Leisk
    41,418
    Boroscope the cylinders.
    4th gen's are prone to head gasket failure if Exhaust Heat Recovery (EHR) system springs a leak (which it's prone to), and it's neglected for some time, leading to one or more times where the engine had insufficient coolant.
  3. BiomedO1
    BiomedO1 Senior Member
    3,585
    1,856
    SacTown, Ca
    I'm using the Walmart SuperTech 20K miles formulation, not the cheaper 10K mile one.
    I just looked as my last jug of oil; could've sworn the oil blender/manufacturers' name and address used to be there - at least not on this jug. You may want to look at the Amazon & Kirkland jugs to see who's blending the oil for them.
    Like you, I've got low actual ICE mileage on mine, but probably at least double or triple your ICE mileage when I do my annual oil changes. I usually fill-up every month or month and a half with over 1K miles on a tank of gas. The oil color is usually a very light honey brown, when it gets changed. Like I stated earlier, I need to use a tissue to figure out where the oil level is on the dip stick for the next 3 months after a change, because I can't see it.
  4. Cuauhtemoc
    Cuauhtemoc New Member
    Mexico
    Recently, I experienced noise and significant vibration when the engine was cold or when the gasoline motor started operating. I took the vehicle to a repair shop, and they replaced the engine mount, transmission mount, and another motor mount as well. This completely resolved the issue. I’m not sure if this information might give you an idea of what could be happening.
  5. BiomedO1
    3,585
    1,856
    SacTown, Ca
    I suggest you watch your coolant levels - BOTH coolant jugs!!!! 2016-2017 Prius has been know to leak coolant into the heat exchanger, which will cause your motor to overheat. If you ignore this condition, you'll blow up your engine.
    Motor mount failures are very uncommon in these cars.
    Hope this helps....
