2021 Prius prime cabin noise above 30+mph
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by seeforyourself, Mar 2, 2021.
  1. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    Worth a try! Thanks for sharing.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,151
    Tampa, FL
    That's where I keep my Yokohamas anyway. 42 front, 40 rear. Very comfortable and perfectly even wear.
    But whether you like the doorpost pressure or something higher, if it's flat spots, they'll go away in a while anyway. :)
    don_chuwish likes this.
  3. don_chuwish
    823
    190
    Southern Oregon
    It's been a couple of weeks now since I adjusted tire pressure. They weren't as low as the door sticker but I did add a couple of psi all around. Also got them more consistently set than they were.
    So far I think it might be helping. Can't be sure just yet.
  4. Peng Xiao
    Peng Xiao Junior Member
    84
    New Jersey
    2018 Prius Prime
    Replaced Toyo with 2 Bridgestone Ecopia EP422 Plus on rear, both wife and I noticed the noise.
  5. don_chuwish
    823
    190
    Southern Oregon
    Sorry, you mean you noticed the noise before changing the tires? Did the new tires fix the noise?
  6. Peng Xiao
    84
    New Jersey
    2018 Prius Prime
    We noticed the noise AFTER changing the tires.
  7. Peng Xiao
    84
    New Jersey
    2018 Prius Prime
  8. Peng Xiao
    84
    New Jersey
    2018 Prius Prime
    I moved 2 Ecopia EP422 Plus to front, Toyo to rear, feel better, hear less noise. Probably front has better noise isolation.
