276K and my transaxle finally went
Discussion in 'Gen 2 Prius Main Forum' started by DGESSWIN, Jun 27, 2017.
  1. DGESSWIN
    DGESSWIN Junior Member
    35
    Connecticut
    OK, so I have been on this forum for a very long time. don't really post anything (car has been absolutely great to me!) 2006 gen 2 and I have only done what I considered bare bones maintenance. meaning: I change my oil at 5k with synthetic. brake pads once. plugs once at 225K 3 sets of tires. and recently did shocks struts and springs. New battery. all the filters are done as needed. I had no idea that it was necessary to change the transaxle fluid. I noticed my gas mileage dropped from 49+mpg to low 40's ok, but then I went down to <20mpg and slipping and that nasty VSC red triangle/ so my transaxle has almost failed . so I bought a 111K mile used one from the local bone yard for 159 out the door and tomorrow I begin my journey to replace it. LAM did a great write up on how to do it and tomorrow morning I begin my adventure. no chance of me giving up at this point as the car owes me nothing. which is a good thing because I am not wealthy at all and it took me a few weeks to buy the transaxle. I have noticed some posted about viscosity testing. if anyone wants my oil to send out for testing and they are willing to pay for it. I will gladly save it for you. so I am just throwing it out there. I don't wish to profit from this in anyway. Also the parts yard I bought from has drained the transaxle fluid and removed the filter? where is that located and what else would you advise replacing while I have the transmission out. I will be dropping the transmission in my driveway. thanks! Don
  2. ChapmanF
    18,964
    Have you checked into the diagnostic codes behind those VSC and red-triangle lights yet?
    "Slipping" is not a thing a Prius transaxle can even mechanically do, so symptoms that "feel like" slipping generally have some other cause, which the computers will help pin down for you. Would be unfortunate to do a very labor intensive repair before determining what needs to be repaired.
    -Chap
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I agree chap. DGESSWIN Why do you think it's the transaxle?
    Hope it's not a hi volt ground fault because that's probably the hybrid battery.
    And when your testing the trans fluid it's to test for contaminants not viscosity. The fact that your your asking about a trans filter seems to me your not even close to ready to pull the trans.
    MilkyWay likes this.
  4. DGESSWIN
    35
    Connecticut
    the transaxle isn't slipping there just is a tremendous loss of power and gas engine runs at high rpms. I clear the codes reset it it's normal. For a few minutes. What do you recommend I do? I have a hand scan tool. I did buy new transaxle fluid. Should I drain that first? I am mechanical and built my own mustang forged 650hp engine. Just reading everything I believed it's transaxle. What should I do? Like I said in first post. I'm pretty broke and can't afford to throw money at this blindly. Without my car I have no work. Thanks in advance guys.
    Don
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    These same symptoms can point to a failed hybrid battery. What were the codes?
    edthefox5 likes this.
  6. JC91006
    16,934
    8,644
    I agree, you shouldn't do anything until reading the codes
  7. DGESSWIN
    35
    Connecticut
    He code is P0A80 , I disconnected the aux battery last night. Cleared the codes and the car started (well I had to. Jump it) it has sat for 15 minutes no codes and I. Have watched the battery charge up on the screen. Although there are no codes right now the gas engine turns on for a couple seconds then shuts off repeatedly.
  8. fotomoto
    5,639
    3,815
    So. Texas
    You have a failed hybrid battery.
    MilkyWay and Deogratias like this.
  9. DGESSWIN
    35
    Connecticut
    Oh. Shit.... It can't be anything else? My thoughts were the transaxle was shorting out and not charging the hybrid battery. Or am I just dreaming?
  10. JC91006
    16,934
    8,644
    Dreaming
    But I think you can fix this yourself. It's way easier than doing a transaxle
    #10 JC91006, Jun 27, 2017
    Deogratias likes this.
  11. DGESSWIN
    35
    Connecticut
    Ok, please do tell.
  12. JC91006
    16,934
    8,644
    If you're just trying to buy some time, you can do a simple module swap. Change out the bad module. No real equipment needed
    If you want a longer lasting repair, you would need to charge and discharge the battery pack. This would need equipment
    You can watch some YouTube videos to get a general idea of what's involved
  13. DGESSWIN
    35
    Connecticut
    I do have an electrical engineering back ground so this seems feasible.i wonder if I can return that transaxle? I will look into this . Thanks for your help.
  14. fotomoto
    5,639
    3,815
    So. Texas
    MilkyWay, m.wynn, Deogratias and 2 others like this.
  15. Deogratias
    Deogratias Member
    37
    42
    Just curious - did a hybrid battery fix this problem? Or was it really a transaxle issue after all?
  16. DGESSWIN
    35
    Connecticut
    It was not the transaxle it definitely was the HV battery pack. After I replaced the pack I took apart my battery pack and found I had one bad module. Right In the middle.
    Deogratias, MilkyWay and Raytheeagle like this.
  17. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    Good job. What was the time invested and cost of parts to get it back on the road?
  18. edthefox5
    10,096
    4,837
    Clearwater, Florida
    P3021 is the middle module and gets cooked,
  19. stephanie_elise
    stephanie_elise New Member
    Orange County, CA
    I'm curious how much it was to do the brakes, shocks and plugs, mine needs this as well as a new battery.
  20. DGESSWIN
    35
    Connecticut
    The parts for the Prius are pretty cheap. I buy everything on EBay. I love my car and financially I can't afford a new car. Front pads are 8$ rear shoes 13$ plugs were 25$ for the four of them .shocks and struts are 110$ all of these parts are simple to install. To do the rear shocks you will need to take out the entire trunk interior and back seat. It seems like a lot of work, but it's really easy to do. Just time consuming. And after you have done it once, the next time you take it out say to replace your HV battery you will be very fast. The front struts you will need to take off the wipers, wiper motor, the tray that it sits on. Sounds scary but really easy to do once you give into the fact that you have to do it.
    It takes me about 35 minutes to do the plugs. 2 hrs to do the battery. I bought my battery used from a member and he gave me a great deal.
    stephanie_elise likes this.
