3rd gen model year and oil consumption
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, Nov 19, 2018.
  1. 2010~2013 with minimal oil consumption
    56 vote(s)
    47.5%
  2. 2010~2013 with moderate oil consumption
    18 vote(s)
    15.3%
  3. 2010~2013 with heavy oil consumption
    22 vote(s)
    18.6%
  4. 2014 with minimal oil consumption
    5 vote(s)
    4.2%
  5. 2014 with moderate oil consumption
    2 vote(s)
    1.7%
  6. 2014 with heavy oil consumption
    0 vote(s)
    0.0%
  7. 2015 with minimal oil consumption
    18 vote(s)
    15.3%
  8. 2015 with moderate oil consumption
    0 vote(s)
    0.0%
  9. 2015 with heavy oil consumption
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    Another year since I checked in with my '14 info. Another 35,000 miles added to the odo bringing my total miles to 182,000. Still no problem with oil consumption. Seems like a lot more 2010's than than that of the later years of gen 3's. i know when i bought my '14 that some people were holding out for a 4th gen. Also, gas prices have not been as bad as 2013. When I bought my car, the gas prices were down but I was fully expecting 4.00 a gallon gas again. Been under 3.00 and currently barely over 2.00 a gallon where I live.
    Bay Stater, m.wynn and Mendel Leisk like this.
  2. Stangar
    Stangar Active Member
    174
    174
    Palmdale, CA
    Merry Christmas! I voted. 2011 Prius purchased new March 2011. The vehicle operates in a desert climate (Southern California) with temp between 30 and 105 F. Mainly highway driving. No oil consumption at 226,750 miles. 5000 mile oil change intervals with Mobil 1, Synthetic, 0W-20 and Toyota brand oil filter. I input a small bottle of Techron fuel injector cleaner around 500 miles prior to each oil change.
    At 170K miles, the EGR cooler and manifold were cleaned and an oil catch can installed. Water pump replaced for preventative maintenance.
    I’ve only had one tank of fuel that provided less than 50 mpg and usually fill up every 550 miles.
    By the way, I seldom exceed the speed limit.
    #62 Stangar, Dec 25, 2019
  3. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    What was the condition of your EGR cooler with 170K?
  4. Bay Stater
    534
    771
    Central Mass
    Have you cleaned your EGR System? Installed an OCC?
  5. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Just voted. Mine is 2010 at 165k miles (Mobil-1 0w 20) with OCC so far oil change got done at 5000mile interval with OEM filter replaced the same time..
    I never realized any oil consumption but I am pretty sure it uses some. It must be very minimal though. Can't see anything on the dipstick.
    Is there any more accurate way to check it other than the dipstick method?
    Bay Stater and Mendel Leisk like this.
  6. Mendel Leisk
    42,228
    Wait as sec, as in: there's no oil showing on the dipstick? Or it's so clear and messed around it's hard to tell? For the latter:
    Pull the dipsitick and wipe it off. Wait 5 minutes. Push it fully back in and withdraw to read: it should have a more distinct cut-off now.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_O
    RMB likes this.
  8. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I presume he means there's no perceivable change in oil level on the dipstick.
  9. ASRDogman
    ASRDogman Senior Member
    8,014
    4,071
    New oil is hard to see on the dipstick. You can pull it, wipe it off, put it back in and pull it again,
    and then lay it on a clean paper towel. You'll see the towel absorb the oil, then you can tell how high
    on the dip stick it is.
    You can also shine a bright flashlight on it...
    Bay Stater likes this.
  10. Eric34
    Eric34 New Member
    Sacramento
    2014 Prius 3rd Gen 238k miles driving it like I have 5 more Priuses. Driven about 5000K in every 5 weeks. 1st suspension job done at 220k miles due to failing 1 strut on driver site. 1 set of strut suspension assembly for front and new struts on rear axels. Maintained meticulously. Scratches, Spotless. Serviced up to 200k 5K OCI. Since then 7.5k OCI only 0w-20 Super Tech full synthetic oil. (API SN, GS 5, Dexos 1 ) made in China unbranded cartridge oil filter. No oil consumption.
    #70 Eric34, May 6, 2020
  11. Mendel Leisk
    42,228
    Contrary to my first post, it now seems "somewhere" through model year 2014 the pistons and rings were revised, at the same time. You may be pre or post revision, hard to say. Thanks for the report.
    Aaron Vitolins and StarCaller like this.
  12. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    now it would be interesting to know starting from what vin on they changed what /
  13. hotelprisoner
    hotelprisoner Member
    104
    87
    Ontario, Canada
    Technology
  14. Mendel Leisk
    42,228
    ^ OMG the answer's been hiding in plain sight! Thanks!
    Snippet from the first of the two bulletins:
    Why would there be two commencement VIN's (in a couple of the cases)? Two different factories?
  15. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    Yes, that would make sense. Quick deciphering of the VIN there:
    The # in digit 9 is a check digit - does not mean anything other than to confirm validity of the whole VIN
    The E in digit 10 means model year 2014. So when they say "before" this means that all 2010-2013 count, and then some of the 2014.
    Digit 12-17 are the serial number.
    Digit 11 is the plant. So the two different plants were working with different serial number sequences.
    kc5dlo, RMB, Bay Stater and 3 others like this.
  16. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    1 quart per 1k miles in city or highway drive. Worn piston rings effects way more in high speed > 70mph. I used to drive Nissan Altima 2002, it burns oil 0.5 q per 1000 miles in average. But it burn 1 quart every 1000 miles in exclusive highway drive. Piston rings too slow to adapts at higher speed and will leak more oil. Now I drove Toyota Prius 2015 and it burns less than 100cc of oil in 10k miles at 70k miles odometer. 2015 piston+rings are really good even I often drove at 80mph for 4-5 hours.
  17. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    My 2010 (Delivery 7/19/09) has a little over 91K on the clock and burns ZERO oil. I check the oil the morning that I'm taking it in for it's service at the dealer, and it's always right at the full mark on the stick. I have the oil changed twice a year roughly every six months around 4,000-4,300 miles. The car has only had Toyota 0W20 in it from day one. Mostly short trips with an occasional road trip of an hour or two.
    The other issue that I feel contributes to the lack of oil usage is that the car never exceeds 65 mph except to pass a slower vehicle. I run it at or below the speed limit on the highway. That means if the speed limit is 70 mph you will find me in the right lane at 65 mph. The engine in this car is built for low speed economy, not screaming up the Interstate at 75 plus mph for hours on end.
  18. ASRDogman
    8,014
    4,071
    You sound like me! :)
    But I'm the 2nd owner, and that's how he drove.
    Though mine uses about 1 qt in 10,000 miles...
    ALS likes this.
  19. TacoPrius
    TacoPrius New Member
    Aurora, CO
    Four Touring
    2010 with 198k miles on it. I purchased it in 2016 with 104k. Did 10k oil change intervals with Mobil 1 0/20 and then Lucas 0/20 after I started working for a Lucas distributor last year. Not much oil consumption until April or May of this year. It used to burn maybe 1 quart every 5k and now it's 1 quart or more every 1k miles.
    I cleaned out the EGR system, cleaned intake manifold, and replaced the PCV valve in May. I also had a check engine light that turned out to be a bad air/fuel ratio sensor. Dealer replaced that for over $600. I wasn't at 10k yet when I did my last oil change but I had topped off several quarts by then. I flushed the engine first with the BG EPR (Engine Performance Restoration) stuff, before changing the oil and filter like normal. The old oil came out jet black, definitely pretty nasty and a lot nastier than usual. So I thought my piston rings were just gunked up and not excessively worn.
    The oil consumption seemed to decrease for maybe the first 2k miles after the EPR treatment and oil change. Then it seemed to go crazy again and I have already topped off one quart of oil. Then added a quart of Lucas Synthetic Stabilizer after it ate that quart.
    Meanwhile, I also have a 2010 Tacoma with the 4.0 liter V6. I bought it used last year in August with 148,xxx. It now has about 153k miles on it, definitely my backup/fun vehicle. I changed the oil shortly after purchasing the truck and it has barely gone down on the dipstick since then. Only 18-20 mpg of course, loves that nectar, but hardly consumes a drop of oil. I've done several maintenance items on it and it should last me a few more Priuses LOL.
  20. Stangar
    174
    174
    Palmdale, CA
    Sorry to have not replied until now. My EGR cooler was in bad shape/highly clogged at 170K. I did the work to remove and replace with a new cooler and it was not a easy/small task. The next time it will go much smoother. This effort will greatly improve the engine longevity.
