A/C errors B1380, B1383 and B1423
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by alinica2001, Jul 21, 2019.
  1. alinica2001
    alinica2001 Junior Member
    34
    Romania
    Hello,
    As a result of a small impact on the right side, I have the above errors on HVAC system.
    Any idea what B1380 and B1383 means ? B1423 is clear ( open or low pressure ).
    Thanks!
  2. Alvin Huang
    Alvin Huang Junior Member
    22
    Taiwan
    B1380 - External Condenser Refrigerant Temperature Sensor Circuit, Open or short in heat exchanger temperature sensor circuit
    • Heat exchanger temperature sensor
    • Harness or connector
    • Heat pump ECU assembly
    B1383 - Middle Pressure Magnetic Valve Malfunction, Open or short in No. 1 air conditioning accessory assembly (middle pressure magnetic valve) circuit
    • No. 1 air conditioning accessory assembly (middle pressure magnetic valve)
    • FAN NO. 2 relay
    alinica2001 and Prius from Dad like this.
  3. alinica2001
    34
    Romania
