A/C light blinks sometimes
Discussion in 'Generation 1 Prius Discussion' started by Victor Siles, Jul 16, 2025.
  1. Victor Siles
    Victor Siles Junior Member
    51
    Garden City
    2001 Prius
    I
    My A/C blinks sometimes like 15 mins after I started the engine. I push the A/C light off wait about 2 mins and push it on again. Usually it stays on depending how long I get stuck in traffic. I had the mechanic charge my A/C a few months ago. Has anyone else experienced this before?
  2. ChapmanF
    19,040
    Review this thread:
    A/C Clutch Diagnosis and Replacement | PriusChat
    Be sure to read through the whole thread. It starts out, regrettably, with instructions on replacing the entire compressor clutch. Be sure to keep reading until you've learned about the ten-minute job of simply replacing the one-dollar clutch adjustment shim.
    It is kind of amazing that your 2001 has gone this long before needing the shim changed.
    mroberds, Jakob and douglasjre like this.
  3. Tombukt2
    Tombukt2 Senior Member
    13,867
    2,520
    Durham NC
    That's wild on my Corollas I've replaced 1 once . The wavy washer on the what is it ten mm clutch nut on the Denso clutch . . So I guess they get hot lose the wave or such.
  4. ChapmanF
    19,040
    No, the faces of the clutch wear away, so the clutch clearance goes out of spec. The shims under the pressure plate are not some wavy washer, they come in a set of 3 precise thicknesses, you measure the clutch clearance, do some math, then use the right shim or combination of shims so the clearance is in spec again.
    If the clearance is too close, the clutch will drag when the A/C is off. Too great, and it will slip when on, giving you the blinky A/C light and the 22 code.
    #4 ChapmanF, Jul 17, 2025
    douglasjre likes this.
  5. Tombukt2
    13,867
    2,520
    Durham NC
    Yeah my bad the wavy washer is on the outside of the assembly youre talking about the shims . Usually I guess compressors about gone in SE area by the time the clearences start dragging etc here . I played around once in a Corolla and a Celica w Denso compressor. the compressors were weak more than anything. Change and almost snow coming out vents.
  6. ChapmanF
    19,040
    Wear on the clutch faces inexorably changes the clearance in the too-great direction, so that the clutch will eventually slip while engaged, leading to the blinky A/C light and the 22 code.
    When adjusting the clearance with shims, it is possible to overcompensate and end up with clearance too close, in which case the clutch can drag a bit when A/C should be off.
    mroberds and douglasjre like this.
  7. Victor Siles
    51
    Garden City
    2001 Prius
    I
    Thank you for your response. I'll check it out, but one thing my car did not show a code 22. I'll check again when the A/C light starts to blink again.
  8. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Is it possible his AC is overcharged?
  9. ChapmanF
    19,040
    It might be possible a severe overcharge could be responsible for clutch slippage.
    But in any high-miles car with a magnetic A/C clutch slipping, it's generally not necessary to cast a real wide net for explanations why.
    mroberds likes this.
  10. douglasjre
    2,250
    751
    Null, NL
    Does the turd gen have an overpressure sensor that safety's it off
  11. ChapmanF
    19,040
    Um, this whole thread is about gen 1, which is the only gen having a belt-driven, magnetic-clutch compressor and requiring occasional clutch gap adjustment. Any other gen is a whole different ball of wax.
    #11 ChapmanF, Jul 20, 2025
  12. douglasjre
    2,250
    751
    Null, NL
    I hear ya. Just wondering if the turd gen has a hi sensor. Do u know if it does
  13. ChapmanF
    19,040
