A/C Stuck, working but won't change positions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AvTech72, May 12, 2023.
  1. AvTech72
    AvTech72 Junior Member
    32
    Miami Beach, FL 33140
    Three Touring
    Hello fellow Priusers =)
    Luckily my a/c is working and blowing cold but somehow the position is stuck blowing both forward and lower to the feet area.
    With warm weather in South Florida, it's nice to have cold air blowing at me, not my feet.
    Outside vents closest to windows blow normal and inner vents closest to dash are almost nill(i assume normal for forward and lower blowing)
    Any input to unstuck what's not working would be greatly appreciated!
  2. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    First step is to eliminate or replace cabin air filter... Then once you're certain you have max air pressure start switching between vent settings and temperature settings to exercise the motors/servos that control the valves... You can usually loosen up things that way. As in as cars get older they have a difficult time switching from winter floor heat settings to in your face summer AC settings. Of course you're in Florida, so... Maybe just buy a new car.
  3. Tombukt2
    Tombukt2 Senior Member
    13,861
    2,519
    Durham NC
    The door or barrel thing that's in the ductwork is not moving in positioning itself where you want the air to come out I have not looked into this real hard on the Prius but in older other Toyotas this all used to be cable operated it was a physical cable that went from the floor position to the defrost position and to the vents that blow in your face position now in the Prius all of this is electrical etc so you have to get the codes for the AC system by pushing some buttons and then transferring those codes back to your post and it'll tell you basically what's not happening That's the easiest way or you can find Said servo. And clamp it to the position you want it to stay in that may be a thing if you don't want to do the other I'm with you though I'm in North Carolina and it's very hot in the summer funny this year we're kind of going to be late bloomers it looks like for the heat.
  4. ChapmanF
    19,025
    In fewer words with more punctuation, hold down the steering wheel 'auto' and 'fresh/recirc' buttons while turning the car on, then let us know what two-digit codes show up on the MFD.
    AvTech72 likes this.
  5. AvTech72
    32
    Three Touring
    21, 33, and 43 are flashing with the normal forward vent icon flashing at the same time
    Neat trick!
  6. ChapmanF
    19,025
    21 is a distraction. The code just exists so you have a way to tell if the solar sensor on the dash works. In shade, you have code 21, and in full sun, you don't, and that's how you can tell. It doesn't indicate any problem (unless you have it in full sun, or you don't have it in shade :)).
    B1433 and B1443 are both codes about the actuator that moves the air outlet selector vane. So that goes right along with the behavior you've described. B1443 reports that the sensed position of the vane doesn't seem to be changing when power is sent to the motor to move the vane. That could be something jammed, a bad motor, or a problem with the position sensor or wiring. B1433 is specific to the position sensor or wiring; the signal coming back doesn't seem reasonable.
    Looks like somebody uploaded that section of the repair manual here in the past:
    https://attachments.priuschat.com/attachment-files/2020/06/188086_AC_-_Air_Conditioning.pdf
    The position sensors in the Gen 1 and Gen 2 actuators get flaky with some regularity, and sometimes are easy to fix, as you can read about in this thread:
    No, that wasn't a mouse in the heater | PriusChat
    Of the three actuators, the outlet select one isn't the easiest one to get to, but it isn't the hardest one either. (Goldilocks strikes again.)
    If you read along in that thread until you learn about yitznewton's nifty screwdriver solution for the hard-to-access screw ... he's talking about the air mix actuator (that's the easiest one), but the outlet select one is just a bit upward from there.
    But sometimes motors and vane linkages also can get worn out or jammed up or broken, or mice chew the wires, so it might not always turn out to be the just-clean-the-sensor situation that thread describes.
    SFO likes this.
  7. AvTech72
    32
    Three Touring
    Ok, will read deeper into the thread you CC and the instructions, but overall seems like I will have to access these motors and see if they are receiving power and are just stuck. or the cable/motor is fried and just need a new one
    Thanks for all the info, very grateful!
