Aftermarket CAT.-I keep getting code PO420=O2 sensor
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Feb 14, 2023.
  1. ski.dive
    ski.dive Active Member
    967
    247
    Hutchinson Island,FL. Mt. Snow,VT
    Aftermarket CAT.--- I keep getting code PO420=O2 sensor
  2. qmanqman
    qmanqman Active Member
    443
    153
    CO
    Me too.
    I changed both O2 sensors prior to the cat and that didn't fix it so I changed the cat. P0420 keeps coming back.
    Checked the spark plugs the other day and they were shot so I put new plugs. I'm hoping this will help. Gonna keep turning the code off and see if it will stop coming back.
  3. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
  4. ChapmanF
    18,957
    What makes you think that?
    The P0420 code (note that's a zero 0, not a letter O) tells you the cat that's installed has less than the needed oxygen storage capacity.
    The sensor is involved in determining that. But to say the code is about the sensor would be like seeing an overheat warning light and changing the water temperature sensor to fix it.
  5. bisco
    52,776
    there are some threads here with aftermarket cats proven to work well
  6. PriusCamper
    PriusCamper Senior Member
    13,403
    5,412
    Pacific Northwest, USA
    As often as I've told someone how ridiculous it is to replace the O2 sensor rather than get the engine burning cleaner, it's futile.
    Also I finally got to a point with a Gen2 I've been working on where I've exhausted all the options other than replacing the O2 sensor to address PO420. And yes I just used a O instead of a zero when typing that error code because I know how much it upsets you when a zero looks like an O.
  7. ChapmanF
    18,957
    It's not a matter of me being upset, it's me making sure people who read the thread later will understand they'll get much better info if they spell the codes right when searching for them online.
    That's just it anyway: a zero never does look like an O. By typing it with an O, you didn't make a zero look like an O, you just typed the wrong thing where a 0 belonged. Which is ok if that floats your boat, as long as everybody understands you get impaired search results if you do that when searching.
    #7 ChapmanF, Feb 14, 2023
  8. drone13
    drone13 Active Member
    140
    115
    SoCal
    My opinion is why would anyone do either of the things you mention without data to say it would be helpful? Checking engine operation and O2 operation is part of the basic diagnostics when approaching a P0420 event, as is checking for exhaust leaks. Eliminating subsystem issues is pretty quick and easy. I think quicker and easier than changing O2 sensor(s) and having to drive the time-consuming test pattern to prove or disprove turning a quick diagnostic exercise into a multi-day adventure. If your diagnostics leads you the conclusion the engine is running out of spec or the O2 is not functioning properly, then by all means fix the issue before proceeding, but absent any data to prove/disprove it's more just a waste of time.
  9. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    And in tec stream all these items that are suspect should be oranged in health check? Right. I see my p042o code orange but then in list everything looks normal 02 readings etc.
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
  11. The Lizard King
    89
    56
    IIRC, OP removed his OEM cat, sold it, and bought an aftermarket one.
    Sometimes you reap what you sow.
  12. highmilesgarage
    highmilesgarage Active Member
    494
    182
    Kansas City
    PO420=O2 sensor=EXPENSIVE PARTS CANON APPROACH
    Lots of stuff that could trigger p0420 and the sensor is just the messenger, 99% of the time it's not the sensor.
  13. drone13
    140
    115
    SoCal
    Agreed. Also, it's more expensive to buy a single rear O2 sensor than it is to buy the appropriate VCI cable and Techstream and be able to diagnose the actual cause. Makes no sense to throw parts at a problem without a clue whether it will even help. Unfortunately, for many the hail-mary parts changer method seems to be a popular method to address a technical issue. Plus, if you spend the 30~$35 on a Techstream diagnostic system you are now setup for any future problem you will encounter with a Prius and can at the very least give the data to more experienced members here at PC the real information to help find any issues now and in the future.
    It is true there are outlier problems that can cause a P0420 besides a cat, but without data to diagnose the issue there is very little chance of a positive outcome. Even worse, if you do have a different problem and buy a new expensive cat, it will mask the real problem even though the P0420 will likely go away for a while. It would be very discouraging to buy a $2300 cat and have the problem reoccur later. Or buy a cheap ebay cat and have the issue reoccur after a while and always wonder if it's just the cheap cat while being oblivious of the real issue due to lack of accurate data to lead to a proper diagnosis.
    I guess it's the car owner's choice on how they approach their problems.
  14. bisco
    52,776
    don't scan it and you won't get the code
