Aftermarket PCV valve
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by shan k, Jan 20, 2020.
  1. shan k
    shan k Junior Member
    Hi Friends
    Recently I replaced PCV valve with a after market one (Intermotor PCV477) in my 2006 Prius with 113k miles. I bought it from advanced auto parts.
    Question: 1. Has anyone ever replaced with that brand?
    2. Is it good quality compared to OEM?
    Have driven 500 miles since then and have not experienced any issue so far. Car is running just fine. My concern is and I am little bit worry about the part as being after market and what if it suddenly fails. Thank you
  2. JC91006
    16,939
    8,647
    1 - the original part probably never failed, so it probably didn't need replacement.
    2 - you'll be fine with an aftermarket part, no worries
    SFO likes this.
  3. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Welcome to PriusChat!!
    If you're concerned about quality issues regarding aftermarket parts, why not just buy OEM parts and not worry about it?
    edthefox5 likes this.
  4. eternalphoenix64
    eternalphoenix64 Junior Member
    44
    Battle Ground, WA
    There are places where you can get aftermarket and not worry about it.
    There are places where you can get aftermarket and should worry about it, but it's ok.
    There are places where you can get aftermarket and shouldn't
    There are places where you can get aftermarket and mustn't
    There are places where you cannot get aftermarket and have no choice
    A PCV, in general, falls into the first category. I mean.... don't go getting the cheapest, grossest Chinese POS you can find - but pretty much any PCV valve you buy at a parts store will work. It's basically just a check valve - a metal ball inside a plastic sleeve with a spring
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Replacing the pcv valve is only half of the job. If you follow the hose that connects to the pcv down to the throttle boy and pull it off the throttle body you may find that hose connection there is clogged with gunk.
    You have to thoroughly clean the throttle body with choke cleaner.
    Inspect the 2 hose ends for cracked ends thats common too.
    Basic maintenance.
  6. shan k
    Thanks for explaining it so nicely. Really appreciate that.
    Thanks for the suggestion. Yes I did cleaned throttle body as well when I replaced pcv valve.
    Thanks for the reply. Yes you are right. I just realized it after reading the PC conversations but it was too late since I already had it installed. Anyway I would definitely prefer to use OEM replacement as much as I can. Thank you again for the feedback.
    #6 shan k, Jan 21, 2020
    SFO likes this.
  7. Berch1943
    Berch1943 Member
    146
    Arizona
  8. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    A quick search for "PCV torque" here on PC, yielded this : https://priuschat.com/search/191426725/?q=pcv+torque&o=relevance
    And the second result from the top, was this thread : Small crack on engine near PCV Valve | Page 3 | PriusChat
    On the 3rd page of the above thread was a post by @Mendel Leisk : Small crack on engine near PCV Valve | Page 3 | PriusChat
    Which also contains a couple of PDFs, and buried within is : Torque: 27 N*m (275 kgf*cm, 20 ft.*lbf) :whistle:
    Mendel Leisk and Berch1943 like this.
  9. nancytheprius
    nancytheprius Active Member
    365
    157
    iowa
    replaced the pcv valve today and here is my throttle body. looks good to me. any concerns? 06 with 81k IMG_2412.jpg
  10. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Looks very nice to me. Spray some lubricant on the butterfly spring on the outside of the TB and then when you put the air cleaner box back on make sure you tighten the sneaky 10 mm throat clamp under the box.
  11. nancytheprius
    365
    157
    iowa
    thanks! i made sure to tighten the 10mm under the box, but wasn’t aware of the lubrication trick!
  12. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Catch the hood latch too.
