Am I missing a relay?
Discussion in 'Gen 2 Prius Main Forum' started by Elisa daSilva, Apr 13, 2022.
  1. bisco
    52,837
    unfortunately no, the battery case is waterproof. the water problem is very common, and will eventually rust out the body.
    the water often enters under the rain gutter trim. cracks can be sealed with silicone.
    it can also enter under the hatch gasket or hinges. and even sometimes around the tail lights.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    you can see a small rubber plug at the bottom of the battery well toward the front of the car. Pop that rubber plug out and the battery well will stay drained. Will likely be similar on the other side or the car also, under the little plastic storage cubby.
  3. Elisa daSilva
    Elisa daSilva Junior Member
    66
    17
    Biloxi
    Update: just thought I’d let you know that the problem was the HV battery which had 3 bad cells.
  4. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
