Anemic performance in the mountains
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by srivenkat, Jan 6, 2021.
  1. srivenkat
    srivenkat Active Member
    596
    93
    IL
    I personally would wait for the engine to reach operating temp (187F?) before venturing into and past the PWR range to keep wear and tear lower.
  2. ChapmanF
    18,969
    I think you meant #8.
    srivenkat likes this.
  3. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The system was designed to address that. 5 years of colds starts on a regular basis never revealed any wear. That same 2012 Prius PHV is still working fine. (I sold it to a friend.)
    Here's a video of one such drive. Notice how RPM is kept low, despite the hard acceleration up hill on the highway.
    jerrymildred and srivenkat like this.
  4. fuzzy1
    10,688
    My Gen3 can climb a 7% grade pretty well without needing to break 4000 rpm, though it can't be a leader with that artificial restriction, and I do go higher getting up to speed after the ramp. This is at a low altitude, nowhere near Colorado.
    But holding down to just 2400 rpm? That would require turning on emergency flashers to alert others to the slow vehicle ahead of them.
    #24 fuzzy1, Jan 8, 2021
  5. Tideland Prius
    16,673
    I don’t have a scangauge so I can’t test but if torque is needed, would the engine not be spinning at 3,600rpm? (Max torque for Gen 4 Prius). Max power would be if you were trying to go 90mph.
  6. fuzzy1
    10,688
    Thanks to the HSD, max wheel torque is disconnected from max engine torque.
    So just put the engine to max power, then let the HSD figure out the torque-rpm tradeoff at the wheels.
    Tideland Prius likes this.
  7. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    I’d go as far to say this is dangerous and irresponsible driving behavior. Keep up with traffic or get off the road.
    Higher rpms will not hurt the engine. These engines max RPM is still low compared to most engines.
  8. srivenkat
    596
    93
    IL
    I appreciate and agree with the advice. Luckily many places it was 3 lanes and not much traffic, so I could crawl along in the right most lane with the emergency blinkers on. Knowing what I know now, I should have gone into and past the PWR zone, albeit gradually on an engine being broken in, and varied the RPM at the higher ranges for perhaps better break-in.
  9. Leadfoot J. McCoalroller
    8,275
    7,776
    Pennsylvania
    2018 Prius c
    You're way too worried about the effect of RPM on break-in.
    Remember, you're driving an intensely engineered vehicle, completely surrounded by automation. If the car needed a specific break-in routine in order to keep Toyota from paying out engine warranty work, the ECU would be doing it for you.
    Just smile and drive :)
  10. srivenkat
    596
    93
    IL
    Toyota does recommend some care during the first 600 miles, however (the main thing seems to be gradual and varying speeds without hesitating to go into PWR and beyond):
  11. fuzzy1
    10,688
    I hold back on making this criticism because there are heavy trucks climbing at similarly slow speeds. I don't believe in forcing cars to drive faster than speeds that everyone agrees are acceptable for other on-road vehicles.
    But going this slow does demand having hazard flashers turned on, just like those heavy trucks
    And it isn't like these steep climbs are for an extended period. The 7% grades I travel are for significantly less than 10 minutes. They are not like some other places where people are going 90+ mph for hours.
