Another hitch post
Discussion in 'Gen 2 Prius Main Forum' started by ghostwheel, Apr 27, 2021.
  1. ghostwheel
    ghostwheel Junior Member
    30
    Santa Fe, NM
    I know. There are a lot of hitch vs cargo box threads. I read them all. Maybe. I still can't make up my mind.
    I have a 2009 Gen 2 with 190k miles. In pretty good condition, except that it is eating some oil. And only doing 40 mpg or so. We'd like to go on a long road trip, and because we are partly camping inside the Prius, we'd like to carry things outside the Prius. And we did already go on a trip with everything in the Prius, and it was too much of a hassle - moving everything around before you go to sleep. So, the question is where's best. Roof cargo box or hitch cargo box?
    I understand that in terms of fuel economy, hitch cargo box is probably best. But that that could damage the car, wheel alignment, etc.
    I have the following questions:
    1. Echohitch claims 300lbs tongue weight vs. 200lbs for curt. Is that an advantage? Or is the main limitation the car itself?
    2. For causing torque on the attachment to the car, what matters would be how much weight we put in the back, and how long the weight is from the point of attachment. What are good carriers that bring that weight as close as possible to the car? And still far from the ground.
    Advantages to hitch cargo box: easier to reach, cheaper, better fuel economy
    Advantages to roof cargo box: possibly less damaging to the car, possibly more secure against theft
    If the damage to the car risk is serious, it seems that should tilt the balance to rooftop.
  2. PriusCamper
    PriusCamper Senior Member
    13,465
    5,432
    Pacific Northwest, USA
    This is the design I like the best... Much higher mounting position and a you simply cut a square in your bumper cover. I suspect of all the hitches, This one will take you up to highest amount of weight because it's held in place in a way that would allow you to easily add additional bolts:
  3. ghostwheel
    30
    Santa Fe, NM
    Oh, wow. That is pretty cool. This thread: #JimThePrius Overland Conversion in the making. | PriusChat
    I guess I haven't read ALL hitch threads yet. If I understand correctly, this is a self-built hitch. I guess if it is sturdy enough for that overland drive, it should be sturdy enough for me.
    But I have to remove rear bumper cover and read bumper. Would that still be legal?
  4. pasadena_commut
    pasadena_commut Senior Member
    3,067
    952
    Southern California
    While many things could account for that, at least be sure to check the voltage on the 12V battery. Oddly when these are on their way out they really do a number on the MPG. At least that is what happened on my car, with mostly short(ish = 7.5 mile) trips.
    I don't have any experience with hitches on a Prius, but shouldn't there be some wiring also (none is visible in that photo)? Minimally, for driving the brake lights on the trailer.
  5. ghostwheel
    30
    Santa Fe, NM
    Yes, I tested the 12V battery, and it seemed OK. But it was quite old, so I replaced it. Didn't seem to help much.
    I also tested and had Toyota test the main battery. Seems OK. I do align and recondition is from time to time.
    It could have to do with altitude? 7500ft here. Also, the air conditioner is mostly on. Except when I remember to turn it off.
  6. PriusCamper
    13,465
    5,432
    You put bumper cover back on when you're done and it's a stronger bumper... I thing he said it was a Subaru hitch that he did it with... Check that thread for details.
  7. ghostwheel
    30
    Santa Fe, NM
    Thanks, yes. I need to go though it with a lens. Do you think the subaru hitch fit as is, or did he need to cut and weld? I should ask him.
  8. PriusCamper
    13,465
    5,432
    It fit as is... Once you get the measurements figured out, please let us know.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Had a Curt now for 12 years. Well made big bolts right to the mainframe simple bolt on. Bolts are twice the size of the frame bolts in the cut holes in the bumper rig. Tucks under the bumper real good.
    Curt are really good but sometimes the bolt hole location where they meet the frame are not perfect and take a little elongation like mine. a little drilling a little cussing lol..Some are perfect.
    very strong frame. Bought the auxiliary power supply for the lights all plug and play no wire chopping.
    use the search forums link up top and in keyword put. Curt
    etrailer.com
  10. ghostwheel
    30
    Santa Fe, NM
    That sounds good. What did you use it for? Did you carry load on the hitch? I'm thinking of a little box to hold stuff, and try to keep weight down...
  11. ghostwheel
    30
    Santa Fe, NM
    So, I think he used the factory bumper reinforcing bar mounts, and somehow attached them to the Subaru hitch mount. Not sure how. It looks welded. But I guess one could use bolts. It isn't clear how he attached it to the "same tow hook bolts that the Curt ones use".
    I guess I could get a regular mount, something like the Draw-Tite 75236, cut off what I don't need, then get the Curt mount, put the Draw-Title on the bumper using the mounts, and the Curt as directed, and then connect the two together somehow so that the hitch is held by both the underside bolts and the bumper bar mounts.
    This would still be cheaper than the Ecohitch, and probably sturdier. And I would have two hitches.
  12. PriusCamper
    13,465
    5,432
    Yea, once you open it up to this level of modification having welding skills and lots steel stock to choose from is what's going to be the strongest design.
  13. edthefox5
    10,096
    4,837
    Clearwater, Florida
    I don't know why you would go to all that fabrication trouble to just haul a little box.
    I rented a UHaul 8 foot by 4 foot trailer for the day many times for Home Depot assaults. $20. Its a heavy trailer for what it is. Its when i first discovered my hybrid battery was starting to die it was unable to haul that trailer easily. My bought new 07's hybrid was ruined by inactivity. Its my wife's car. Not driven much over the years killed it. Bought a new hybrid battery about 6 months ago so back towing when needed.
    Do you have the original hybrid battery in your car?
    #13 edthefox5, Apr 28, 2021
  14. ghostwheel
    30
    Santa Fe, NM
    I'm just trying to understand the dangers and solutions. There isn't anything in particular I'm worried about. I heard that putting too much weight on the hitch can cause problems with the drivetrain, and would like to see is that is true, and if the danger can be remedied.
    Yes, I do have the original battery.
    I wasn't really worried about the battery with respect to the hitch or the roof carrier. Maybe I should be.
