antenna upgrade? (2nd Gen Prius)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by coyote2, Oct 20, 2017.
  1. coyote2
    coyote2 Member
    148
    36
    Any suggestions for a radio antenna upgrade for a 2005 Prius?
    I don't need it to be short (other threads address that).
    I'm perfectly happy with the original one, but somehow (perhaps vandalism) the antenna's rubbery thicker lower part got mangled. It still works, but the metal inside will get wet now.
  2. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    If you're talking about the antenna mast, they are pretty cheap. Go to Amazon about $16
    The base is another story, they are about $113 at Amazon.
    For the base, your cheapest is from a salvage yard.
  3. coyote2
    coyote2 Member
    148
    36
    Thank you very much for your reply, hchu1. Yes, I'm talking about the mast, not the base.
    Yes, I see. But my question is about an UPGRADE from the original.
  4. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    For some reason when I put the Amazon link it doesn't show up. There are some alternatives listed with the oem unit.
  5. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    Never have this problem again:
    Shark Fin Antenna | PriusChat
    The reception suffers a little bit compared to stock, but the improved look is totally worth it, and who listens to the radio anyway?
  6. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    Me, all the time. :)
  7. coyote2
    coyote2 Member
    148
    36
    I listen to the radio all the time too. I should have been more specific: I'm looking for an upgrade in reception, not appearance. After some googling I'm thinking of buying one that's 25% longer.
    kenoarto, Alive1 and WilDavis like this.
  8. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Despite what your Mom might have told you when you were a young kid, size does matter, :eek: particularly when it comes to antennae! Those sharky finny thingies are smaller and don't have as much gain as the original longies! It's all to do with length, as any radio engineer will tell you! :rolleyes: ;)
  9. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    No, I agree that the stock one had better reception, but I don't listen to the radio that much, and I don't have to worry about removing it before running through a carwash. And did I mention how good it looks?
  10. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Can't wait to hear about the improved reception you may (or not) realize from this purchase :)
    kenoarto likes this.
