Anyone can confirm bolt pattern on 2023+ models?
Discussion in 'Gen 5 Prius Technical Discussion' started by TE37SL, Mar 12, 2023.
  1. Trey Moore
    Trey Moore New Member
    Redondo Beach
    2023 Prius Prime
    SE
    So I assume a 2022 Toyota Corolla rim with 5x100 would not fit? Looking to swap my Prius SE rims for something similar to the Corolla SE rims or the Prius XSE rims.
  2. Merrilea
    Merrilea Junior Member
    Pa
  3. Merrilea
    Pa
    Was just told by a vender that sells spares:
    Unfortunately Prius has 2 bolt patterns in 2023. You have to measure from center of one lug to the center of the next lug to make sure what you need. It will either be a 2.25 or a 2.65.
  4. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    This was resolved earlier in this thread. All wheels have the same hole pattern, except for smaller hole diameters (14 mm vs. 19 mm) for steel wheels offered in Japan.
    Anyone can confirm bolt pattern on 2023+ models? | Page 2 | PriusChat
  5. Merrilea
    Pa
    Was told by a vender selling spares that unfortunately Prius has 2 bolt patterns in 2023. You have to measure from center of one lug to the center of the next lug to make sure what you need. It will either be a 2.25 or a 2.65...
  6. Hammersmith
    Hammersmith Senior Member
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The vender is wrong. All gen5 Priuses have a 5 x 114.3mm bolt pattern. No gen5s have the 5x100.
