Anyone know how to disable TPMS ?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by georgekessel, Mar 6, 2010.
  1. georgekessel
    georgekessel Member
    182
    Has anyone found a way to disable the TPMS yet?
    My winter tires/rims from a previous Prius don't have the TPMS and I'm sick of looking at the light.
  2. dr_d12
    dr_d12 Member
    154
  3. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    The link dr_d12 posted was two threads below the new thread you started. A least read the current threads before you start a new one.
  4. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    Have you considered using a strategically placed piece of black tape?
  5. georgekessel
    georgekessel Member
    182
    I'm using the black tape now, wanted to do something better...
    Mean Kitty likes this.
  6. CaiYanzhang
    CaiYanzhang Junior Member
    Carlifornia
    2011 Prius Alpha
    It is possible to get it done with Techstream cable, 2 minutes' work
  7. StarCaller
    StarCaller Senior Member
    1,244
    697
    Cedar Crest, NM, USA
    you got instructions for that? I have the techstream, but where would I find the procedure?
  8. CaiYanzhang
    Carlifornia
    2011 Prius Alpha
    --Install software
    --Locate "Customize setting" menu
    --Utility
    View some TPMS and ABS values
    --select TMPS on the function menu and click “Data List”. Then you will see all real time data like vehicle speed, sensors ID, intake air temperature as well as each tire pressure and tire temperature etc.
  9. StarCaller
    1,244
    697
    so far so good, but there's no way to disable the tpms/
  10. Den49
    Den49 Member
    498
    268
    Maryland
  11. StarCaller
    1,244
    697
    yep, that's what I did. but with the techstream it would've been a more elegant solution/
  12. douglasjre
    douglasjre Senior Member
    1,856
    647
    Orlando, FL
    I'm not having any luck finding the two wires that I have to jump to disable the TPMS. One of the cheap Chinese sensors that I bought lasted 4 years. I had enough. The car is 14 years old. I don't really care about it and I just don't want the light on the dash. What do I do
  13. black_jmyntrn
    black_jmyntrn Senior Member
    1,289
    336
    2013 Prius Plug-in
    I'd just buy TPMS sensors on Amazon and have them installed in the tires... simple...
    then, when I swap between wheels, just use techstream to update the TPMS system with the IDs of the sensors for the wheels I have installed. I mean... winter driving... wouldn't you want to know if your tire pressure is low?
    Danno5060 likes this.
  14. Mendel Leisk
    38,644
    There’s always a few lights on the dash; what’s one more. Like the passenger seat airbag status for example.
  15. ASRDogman
    ASRDogman Senior Member
    6,054
    3,251
    Just remove all the sensors from the computer using techstream or the D8 or any other
    tool. And/or put a piece of black tape over the spot where the light is. (y):whistle:
