Anyone need a older navigation DVD disc?
Discussion in 'Gen 3 Prius Main Forum' started by IABoy987, Feb 11, 2022.
  1. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    While cleaning out files folders, found this Toyota Navigation map disc. Marked as U93, and Version 11.1
    So free to good home for price of postage. If no response, into the trash it goes.
    kenoarto likes this.
  2. ChapmanF
    19,019
    If it's for a Gen 3 Prius, you might contact this member here who just posted today about needing one. Sounds made in heaven.
  3. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    If this works in my 05, I want it bad!
  4. ConvertibleTech
    ConvertibleTech New Member
    Pahrump
    My wife has a 2011 Toyota Prius III Hatchback! She just got her 12v battery replaced and now Nav, Bluetooth, Radio, and Backup Camera are all not working. Saying needs Nav Map DVD. Is yours still available? I will gladly pay postage for this disc. Is the disc still in good condition? I mean like any damage or scratches on the back of the disc where the data is stored.
    Either way, this is a really generous offer. I would appreciate it greatly if this is still available for me to get for her.
    Thank you!
  5. Tom McCauley
    Tom McCauley Junior Member
    Dayton Ohio
    This appears to be a common problem. The only thing I found was you need to disconnect the battery cables from the battery, then get a shorting cable and connect it to the cables that you took off the battery. Then turn on the headlight switch to drain any residual currrent that may be in the system. Then hook the battery back to the cables you removed previously. Hopefully this will reset the system and these systems will begin to work again.
