Anyway to change outside temperature from Fahrenheit to Celsius?
Discussion in 'Prime Main Forum (2017-2022)' started by kortik, Dec 30, 2017.
  1. Tideland Prius
    16,559
    How the heck did you get a car with metric for everything except temperature?
  2. Prodigyplace
    12,564
    11,779
    Central Virginia
    I think they changed the units.
    What is that 0 mph to the lower left of the speedometer?
  3. UltraJetRefill
    156
    93
    Tucson, AZ
    I think it's the dual speedometer for US cars. Mine does the same when I switch to metric. Do Canadian cars show km/h in that little box when switching to Imperial units?
  4. UltraJetRefill
    156
    93
    Tucson, AZ
    I agree. This little oversight on Toyota's part drives me insane.
  5. UltraJetRefill
    156
    93
    Tucson, AZ
    We just took my wife's Two in for the J0T (wiring harness) recall, and they mentioned a software update. I'll find out this afternoon if that fixed anything. I'm sure it's a 0.00000001% chance, but who knows. I'll report back when I find out.
  6. Prodigyplace
    12,564
    11,779
    Central Virginia
    I had mine in a couple of weeks ago. No mention of a software update, though.
    UltraJetRefill likes this.
  7. UltraJetRefill
    156
    93
    Tucson, AZ
    It was released yesterday. I have to take my Two back. I had the J0T done last week.
  8. Prodigyplace
    12,564
    11,779
    Central Virginia
    Please keep us posted on what you find.
  9. UltraJetRefill
    156
    93
    Tucson, AZ
    It was something to do with the radar activating the brakes in a car wash, unfortunately.
    Prodigyplace likes this.
  10. UltraJetRefill
    156
    93
    Tucson, AZ
  11. Elektroingenieur
    2,515
    3,284
    Three Touring
    Perhaps no one has found it quite bothersome enough to spend $225 or so (U.S.) on the Canadian version of the meter circuit plate, as I suggested in post #2, and discover if it works. (Reading out the firmware and creating a .CUW file is left as an exercise for the reader; bonus points if you change the readout to kelvins.)
  12. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    Anyone found an easy solution? Anyone has the Canadian part No necessary?
  13. UltraJetRefill
    156
    93
    Tucson, AZ
    I'm curious for anyone with a 2020 model. Have they changed anything yet, or are we stick with what it shipped with?
  14. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    I believe there is a part to be changed but I'm not sure which? Someone might be able to give us a specific name.
    It's not under setting or in Carista.
  15. Prodigyplace
    12,564
    11,779
    Central Virginia
    This thread started because of an issue with early 2016 Prius corrected in March 2016 manufacturing date. Your 2017, like mine, can be changed.
  16. UltraJetRefill
    156
    93
    Tucson, AZ
    Wait, you can change the temperature display settings? If so, that would be great! Do you mean just a change in the settings menus, or is this the hardware swap someone mentioned awhile ago?
  17. Prodigyplace
    12,564
    11,779
    Central Virginia
    You can change between miles / kilometers per hour & fuel economy units.Not sure about temperature.
  18. ChapmanF
    18,213
    Does the display have enough digits for that? Or is the bonus only available in very cold places?
  19. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    Bump, anyone found the part to be changed?
  20. Prodigyplace
    12,564
    11,779
    Central Virginia
    You tried the idea mentioned in post 31 here? That is the best guess.
