At what point do you replace the 12v battery?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by mikefocke, Jul 1, 2016.
  1. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    wstt, the ground choice is probably poor. Look in the owners manual for the engine ground or try the strut tower nut/bolt.
    moto g(7) power ?
  2. ChapmanF
    19,009
    +1. I usually find that the positive jump terminal, enclosed in the fuse box, has the metal in decent surface condition, but even unpainted metal exposed under the hood can have an oxide layer that's a surprisingly good insulator. I usually go for the bolts around the edges of the inverter cover, and if I've got a big enough clamp, put it over top and bottom. And scrape it back and forth some.
  3. Mendel Leisk
    42,331
    The stud/nut combo holding down the EGR valve is good too, very close.
  4. wstt
    wstt Member
    148
    26
    I connected to the exact places the owners manual said to. I also tried several other ground spots. Autozone and O’Reilly’s also tried all over and got nothing. I’m wondering if there is a fuze to the positive terminal under the hood or something that could be bad.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    First guess: That picture in your owners manual is really for a different model.
    Second guess: One of your main battery connections is loose or corroded and it takes a SIGNIFICANT current demand for anything to flow.
    What happens if you try to do the measurement with the car in "ready" mode.....on and running ??
    On mine, the "jump point" is also a power distribution point for the WHOLE engine bay.
    I don't think it is possible for that point to be dead and still have the car function.
    NewHybridOwner likes this.
  6. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    The 12V battery is supposed to be about minimum 12.5V after we fully charge and remove surface charge (1 minute headlights on). Below that, it's time to do around.
  7. Air_Boss
    Air_Boss Senior Member
    4,257
    1,195
    New Yawk
