ATF fluid changes ARE Required.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill Norton, Dec 15, 2012.
  1. Former Member 68813
    3,524
    983
    US
    Weird, mine took exactly 3.6 qt.
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I wonder if Toyota is sourcing transmission housings from different sources?
  3. bwilson4web
    16,515
    Ok, this begins to look 'normal':
    Read more: http://priuschat.com/threads/atf-fluid-changes-are-required.119530/page-13#ixzz2SZTOfGgV
    The viscosity decrease is consistent with what we've seen with Type WS and Type T-IV. My oil testing service, R&G Labs of Tampa FL reports that a 15% change in viscosity means the oil is 'worn out'. Other lubrication articles suggests that the polymers added to improve the viscosity range 'shear down' . . . mechanically torn apart by the shear stress. So going from 7.4 to 7.0 makes sense and a 15% decrease for the Mobil 1 would be 6.3 @100C.
    Oil viscosity is a function of temperature so when a more viscous oil is used, it mechanically heats up to a thinner viscosity to a higher operating temperature. So the oil runs hotter, the parts run hotter, and more heat is lost through the cooling path.
    What was abnormal was 12 @100C and the excessive particle load in the first sample.
  4. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    These are suppose to be very good magnetic plugs from a reputable company. A user here made a thread about them....
    Magnetic Oil Drain Plug Automotive Truck Motorcycle Industrial Engine
    User Exstudent provides some good info and pics here....
    Magnetic oil and ATF drain plugs by Goldplug | PriusChat
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    The Redline D6 showed excellent wear numbers on my last UOA. Redline now recommends D4 for the Prius. Called Dave at Redline and he was not able to tell me why only D6 was fine but there Engineering recommends D4.
    Most likely the D6 viscosity was getting to thin over time as it was already thinner than WS.
    I'm coming up on a 25,000 change so will have that UOA'ed over at Wearcheck.
    http://www.redlineoil.com/content/files/tech/ATF%20PDS%201-10.pdf
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I suspect D6 will shear down less than WS does and end up the same viscosity or even better than WS after a bunch of miles.
  7. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    BG Products has a Universal cvt fluid conditioner that is suppose to add wear protection to your fluid....
    BG Universal Synthetic CVT Fluid Conditioner is formulated to enhance the properties of new and used CVT fluid, prolongs fluid life and prevent deposit formation. It improves fluid oxidation stability and anti-wear characteristics. BG CVT Fluid Conditioner is designed for use in both belt- and chain-type CVTs and is compatible with all CVT fluids.
    Part No. 302 11 oz. (325 mL) can
    This is their spec sheet.....
    http://kansasbg.com/Complete_Set_of_Spec_and_Tech/302_SPEC.pdf
    I wonder if this would benefit Prii, or even a specific generation of?
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Not even BG is saying it's suitable for Prius type transmissions.
  9. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    Ok, thanks Xs. Did they say it shouldn't be used in Pri?
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    No, but they only said it's for belt and chain CVTs which the Prius isn't. As a general rule, aftermarket additives are snake oil.
    milkman44 likes this.
  11. Bill Norton
    Bill Norton Senior Member
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    kenichols29 and xs650 like this.
  12. bwilson4web
    16,515
    Honda's belt-CVTs might get some good but the Prius uses an entirely different architecture.
    Dino33ca likes this.
  13. Former Member 68813
    3,524
    983
    US
    It has been explained in this thread: This is why Redline D6 is not the best ATF in Prius | PriusChat
    Your UOA will not show damage to plastic parts.
  14. Bill Norton
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    What will be the symptoms be of this theoretical plastic damage?
    Maybe only time will tell if there are any Gen3 stator failures.
    They might show up in Prii that have never had the ATF changed and the local Toyota dealer sells a new transaxle and us geeks on PC never hear about it. ( All part of the Master Plan????)
  15. Former Member 68813
    3,524
    983
    US
    I see that you didn't bother to read the abstract I linked in the other thread on D6.
    xs650 likes this.
  16. laki007
    laki007 Junior Member
    25
    Poland
  17. El Dobro
    El Dobro A Member
    7,102
    3,282
    That may be iffy. For example, they say it meets GM's Dexron III specs. The only problem is that GM has been using Dexron VI for some time now.
  18. bwilson4web
    16,515
  19. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Bob,
    I have read many posts by you regarding ATF. My Persona has 3,500 miles on it. I was going to change the ATF at 5,000 miles, then at 25,000 and then every 30,000 after that. I was wondering if you agreed with those intervals?
    Thanks!
  20. bwilson4web
    16,515
    With oil testing, yes. However, I suspect that the change interval can stretch out as the initial and residual debris is removed. I do not have the data but Jeff D. has data suggesting 90k miles is the optimum NHW20 change interval. The ZVW30 does not have the silent chain and that should lead to an even longer change interval.
