Attention Prius Owners, I believe I have discovered a previously unknown Mechanism of Low MPG.
Discussion in 'Gen 2 Prius Main Forum' started by TheLastMojojomo, Nov 2, 2021.
  1. Mendel Leisk
    42,118
    Trivia: to convert km/100km to mpg (US gallons), or vice versa, divide either into 235.2. I forget how I arrived at that, but it's just a distillation of the conversion process.
    blaisep and Troy1994 like this.
  2. Troy1994
    Troy1994 New Member
    Netherlands, Europe
    That’s handy, thanks!
    Data Daedalus and Mendel Leisk like this.
  3. Frankusa94
    Frankusa94 Junior Member
    60
    16
    Ma
    Your post made me realize my 07 Prius no longer chirps when doors are locked…and I am also experiencing 40mpg in city and 50+mpg on drives above 40 mph. I did disconnect my 12v a few months… and ICE immediately kicks on with the very little pedal press. Must be an easy way to restore max ev … has anyone spoke to Toyota about this?
    dex3703 likes this.
  4. Frankusa94
    60
    16
    Ma
    You may have not proved it all out yet… but you are onto something that is really happening in my 07 Prius… since 12v battery disconnect a few moths ago. My city mpg is around 38 and above 40 mph… mpg is in low 50s… complete opposite of advertised performance. Gas pedal above 10-15% … kicks ice on… even with a nearly full charge battery…
    Love to hear the finds of this theory….
    Frank
  5. di0tima
    di0tima Junior Member
    nyc
    I am also experiencing this behavior on my prius v — over 50mpg on highway and sub 40 in the city! Would really appreciate a way to reset the low ev mode to high ev!
  6. dolj
    dolj Senior Member
    8,625
    4,380
    Wellington, New Zealand
    I personally believe the (Gen 2) car configures itself in response to the way it is driven.
    If you drive it like a race car, it will configure itself for a sport mode (less economy).
    If you drive it using typical eco-driving techniques (especially pulse-and-glide), it will configure itself for economy driving.
    This is just my observation, take it for what it is worth.
  7. Frankusa94
    60
    16
    Ma
    I Believe Prius v has a ev mode button you could use to force maximum ev operation…
  8. dolj
    dolj Senior Member
    8,625
    4,380
    That's not how the EV button works. Hybrids are not EVs, they are combustion cars. Using the EV button this way is just robbing Peter to pay Paul.
  9. MAX2
    MAX2 Senior Member
    1,436
    489
    101
    Third planet from the Sun
    I'll put in a few cents.
    You have several topics and messages about problems with the fuel system and engine operation of your car. What does the EV mode have to do with it?
    You need to understand the engine operation first.
  10. MAX2
    MAX2 Senior Member
    1,436
    489
    101
    I agree with your theses.
    With an aggressive driving style, fuel consumption for the same distance is higher than with smooth pressing of the gas and brake.
  11. Frankusa94
    60
    16
    Ma
    it doesn’t… I’m trying to solve my highway speed stalling issue on 07 Prius
    I also noticed a drop in city mpg since battery post cleaning … 1000 lies ago… “possible stuck in weak ev mode”
    #131 Frankusa94, Aug 26, 2024
    dex3703 likes this.
  12. Frankusa94
    60
    16
    Ma
  13. Frankusa94
    60
    16
    Ma
    as little as 15- 20 percent pedal/throttle causes engine to kick on… even with all green bars on battery indicator…. This started when I cleaned battery posts 1000 miles ago… seems like Prius stuck in weak ev mode… I think I am also experiencing that phenomenon…. This is a lesser problem compared to highway stalling issue.
    Still searching for answers….
    #133 Frankusa94, Aug 26, 2024
  14. MAX2
    MAX2 Senior Member
    1,436
    489
    101
    It's hard to look for a black cat in a black room where there isn't one.
    Tim22B likes this.
  15. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    181
    US
    I will hopefully have my final video out by the end of this year. I have most of the content I need to make the actual video... I've just delayed making it because I'm distracted by other matters.
    Yes this is a very real phenomenon. There is too much evidence in my own experience and other people's posts where they describe the exact same MAX and WEAK EV State Behavior between 2 Prius or Toyota Hybrids that can't be explained by anything else..
    My guess is there's a process somewhat similar to Ignition Mapping that occurs for the Hybrid Battery. Ignition mapping is where the engine software tests different Ignition points to learn knock values (engine compression causes causes fuel mixture to preignite).
    During prolonged highway driving where the Hybrid Battery can be maintained at roughly 60%... software in the HV ECU does an analysis of the Hybrid Battery based on capacity, resistance, Battery temperature and other factors using methods like columb counting.
    Here is my original post describing increased EV Output after multiple commutes in a row (3rd highlight paragraph):
    Here is a Gen 3 owner that experienced the same thing (3rd highlighted paragraph)
    Both of us drove our vehicles on stop & go drive styles for hours a day due to our jobs. Me in action below:
    I'm driving in the exact same spot in the exact same way multiple days in a row on the mail route. You become very sensitized to how the Hybrid System behaves at different States of Charges and the behavior of the Hybrid System delivering mail like this... which is why I'm the 1st person to connect the dots to all of these other posts and really done the leg work to filter out any other possible causes like stages of Hybrid Operation, Hybrid Battery Temp, etc.
    Now compare two other posts from a 2020 Rav4 Hybrid and 2005 Gen 2 Prius.
    They both describe the same phenomenon of one Hybrid putting out more EV Power than the other despite driving both in the exact same condition.
    That's because one Prius/RAV4 has met the necessary condition to verify it's Hybrid System health via software measurements and allow aggressive usage of EV Output during city driving, and the other has not. Toyota has likely programmed some version of this software into all of their Hybrids... and thisactually led to a lawsuit against them in the 2015 timeframe...
    The cause of the Low EV Output in this lawsuit was misattributed to a software update... where really the software update just activated the latent WEAK EV State Software due to resetting the HV ECU.
    The plaintiffs were right that they were experiencing a loss of EV Power and mpg in city traffic because of the update... but it was an indirect result rather than direct which led to the lawsuit going knowhere as they were looking in the wrong place in the software for the issue. When they brought it to Toyota's attention, the cause was misplaced and Toyota was 100% correct in that the low EV Output/MPG was not caused by the Software Update.
  16. MAX2
    MAX2 Senior Member
    1,436
    489
    101
    When the 12V battery is disconnected, several ECUs are disconnected.
    The engine ECU resets fuel trim settings and other things.
    This is more important than resetting the high-voltage battery ECU (internal resistance of module pairs from 22-23 milliOhm to 19 milliOhm and the SOC value.
  17. di0tima
    nyc
    I went in for a recall and my ride home had some improved gas mileage. Time will tell, but maybe this could point to a method of resetting?
  18. dtgpnw
    dtgpnw New Member
    PNW, Earth
    I have an '07 that hasn't really demonstrated over 40mpg's over a tank (calculations at the pump) since I've owned it, going to do some tests to see if mine is potentially in this state. my EV battery died and just replaced it with a greentec reman. also noted the lack of chirp when locking/unlocking. seen some posts regarding potential for parameters being held in memory even with battery disconnect etc.
    good read in reading the warpstealth thread various states of the ICE/EV system are called out during warm up, which I'll study for awareness when driving., thinking I may not have driving conditions suitable to enter state 4 waiting for a new ODB-II adapter since my old one is lost. once it arrives I'll use the torque pro and provide some realtime charts data for your project. Cheers!
    some good reading at the org website techno-fandom
    user ~hobbit
    the prius stuff is under slash prius.html
    specifically under link farm (first link) and then five-stages.txt
  19. Ford Galaxie
    Ford Galaxie Member
    63
    30
    16
    Rome, GA
    2014 Prius v wagon
    You ever see those old V6 Buick Century's/LeSabres on the road that appear to be operated by autopilot?
    After passing them you realize that it's just some old lady whose head barely is over the dash. I think the Waymo AI is based on one.
    Yeah, I drive like that. I've disconnect the 12V battery more times than I would have cared to do. So maybe thats why I haven't seen a hit in MPG.
    #139 Ford Galaxie, Nov 29, 2024
  20. Rennie
    Rennie Junior Member
    39
    Australia
    Idk if I've noticed such a state after disconnecting 12V battery. If anything, the ICE on initial startup seems to have lower idle for a few times before returning to normal (normal is what we would call a fast idle on a regular engine).
    I do know that
    - Car will use as much EV as possible while engine is in its initial warm up phase. And then burst into life with an over-rev if you keep requesting normal acceleration as speed increases.
    - Car uses more EV depending if state of charge of traction battery is green bars, or if you've just regen a bit coming down a hill or from highway speeds.
    - EV usage is decreased when battery is getting hot? Or maybe there's motor generator/inverter temps too? Battery fan doesn't have to be running at high speed for this to occur.
    - Engine will remain on for some various reasons, I'm guessing it thinks temperature is too low? (You can check in consumption screen that it is using fuel and not just dumping excess battery charge by spinning the ICE.)
    - EV usage will be very much decreased with low (crimson bars and 3-4) or if traction battery is having issues.
    - The engine will rev heaps and there will be no torque when your traction battery is at a stage where the dash shows warning lights.
    - Regen is severely reduced for a seemingly variable amount of time after a "traction control event" such as slowing down on certain jarring bumps or railway tracks.
