Auto Highbeam
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Bdv, Jul 7, 2021.
  1. Bdv
    Bdv Junior Member
    North Carolina
    My auto highbeam switch is not working on my 2018 Prius Prime. Is there a simple way to replace the switch or is this a dealership repair? If I hold the switch down the dashboard light comes on but it doesn’t stay on if I take pressure off the switch.
  2. Tideland Prius
    16,642
    Is your headlight stalk in the "high beam" position?
    Pulse07 likes this.
  3. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    I wanted to confirm this too. The auto HIGH BEAMS only comes on if the stalk in on High Beams. On regular AUTO or low beams, the auto HIGH BEAMS will not turn on by itself.
  4. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    It sounds like you are pulling the turn signal lever towards you. That is the flash feature. The high beams are activated by pushing the turn signal lever towards the front of the car. Also make sure the headlight switch is on or auto.
  5. Bdv
    Bdv Junior Member
    North Carolina
    not stuck in high beam. Just won’t stay on.
  6. Tideland Prius
    16,642
    I understand.
    What I mean is, you need your headlight stalk in the "high beam" position as well as pressing the "auto high beam" button.
    TGrracie, Pulse07 and Mendel Leisk like this.
  7. Bdv
    Bdv Junior Member
    North Carolina
    The highbeam stalk is in the correct position but the auto highbeam button won’t stay on.
  8. Tideland Prius
    16,642
    Oh that’s odd then.
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    If I understand it correctly, the problem is the toggle switch that is located on the lower part of the dash near the door, that is not staying on?
    I remember reading about someone who had this auto highbeam toggle switch that broke and needed to be replaced. It sounds like that is the case for OP. The switch is easily replaceable DIY. I have not replaced the switches but removed that part of panel with the switch to wrap that piano-black plastic. To remove the panel, use the ply tool to pull it. It will snap off, and After disconnecting the wire harness, the switch part can be removed from the panel and replaced. But I don't know the part number and cost.
  10. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    I had one that would not engage and Toyota replaced it under warranty.
  11. Salamander_King
    11,024
    8,976
    New England
    Then you may be the one who asked me to check if the toggle switch stays flat or indented when engaged. I remember going out to my car and checking it.
  12. pghyndman
    498
    466
    CT shoreline
    Nope, I don't think it was me Sal. Mine was very spongy feeling and no question as to its being defective. Not on my newest Prime, maybe on my 2018 (old age fogginess :sleep: ),
    Salamander_King likes this.
