Axle Seal Leaking - Replace Transmission?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Turbo Heart, Mar 12, 2023.
  1. Turbo Heart
    Turbo Heart Junior Member
    Good day!
    I have a 2007 Toyota Prius
    Has around 180k.
    Got stuck on a hill during a snow storm so I turned traction control off and revved it higher than usual to get uphill.
    Next day noticed fluid underneath the car.
    Replaced the driver axle seal. 3 TIMES
    Keeps leaking.
    - Used Toyota seal twice, then tried an aftermarket seal
    - seal leaks once axles turn (even by hand)
    - first two seals were flush with the transmission case, third seal I had it pertruding a tiny bit
    - axle itself seems fine, no clicks, boot not ripped, no play.
    - when axles are in transmission, there is some play in the trans
    - new Toyota WS fluid
    I'm lost at this point. I'm guessing whatever shaft the axles insert into has worn out? My guess is it's on a bearing? Weird that the passenger side doesn't leak and it moves the exact same amount.
    Any help would be appreciated before I buy an entire transmission tomorrow (and maybe an axle)
    I'll upload videos shortly
  2. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    Funny thing is is it all stops with that seal so that seal has to be right by being seated into the transmission aluminum like it is and then when the axle goes into the transmission that fluted portion of the boot seals around the protruding outer edge of the CV joint or it mirrors it or whatever It's the innie part. Obviously you know how it's supposed to work so I'm not sure by changing the transmission anything gets accomplished the end of the CV joint that goes in to the transmission is going to be wet right up to that seal and then as the transmission fluid gets sloshed around the portion that sealing around the CV joint itself is keeping that fluid from spilling out past it and it just runs back into the transmission and then if the point where it's mounted to the transmission is stable the fluid just runs back down that little channel and into the bottom of the transmission pan or what have you.
  3. Turbo Heart
    Video of the movement inside. Driver side axle removed. Passenger side still in the transmission.
  4. Turbo Heart
    Sadly I dont have enough posts to post links yet. But I do have it on my media page.
  5. Turbo Heart
    yeah true. Maybe I should try just a new CV Axle?
    I put the seal over the axle when it was out to make sure it was the right seal.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    If you want, you can try replacing that drive axle and seal, but that might not work. Look at your picture, there's "galling" of the metal with the diagonal grooves in it- that's where the axle inner joint rides and is held in alignment.
    I have seen this before when someone really spins one wheel. On ice or snow, rev it up so the speedo reads 50mph but the car won't move? The differential spins at 50, the stationary axle is at 0, and the spinning axle hits 100. The axles ride on the steel of the differential carrier. The speed difference between the carrier and each of the drive axle inner joints is 50mph (it's usually near 0).
    The stopped axle is usually ok, but the spinner seems to fling the ATF away and "melts" (smears) the metal wear surfaces. Likely needs a new trans and axle.
  7. Frontporch
    Frontporch Active Member
    547
    127
    Nj
    This sounds dire. If you really do need a trans they are low failure items and inexpensive available at local yards
    from what I remember that seal should be recessed several mm from the case edge. I didn’t have the Toyota tool so I made a loop from 12 gauge bare copper wire and put it on the seal to drive it just below the surface
    trans swap is Lot of work but step by step is on this site
    Turbo Heart likes this.
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    One thing I noticed is that there is a left and a right seal listed. Are you using the correct one?
    Second, the seal is spec'ed to be installed 2.7mm recessed. Your's is flush, so the seal lip is actually riding in a different spot than original. Perhaps trying it at the recessed position?
    Third, procedure specifies coating the seal with grease after installation. Are you doing that?
    Here's a snippet of the repair manual section....
  9. Turbo Heart
    Thanks for the reply everyone!
    this may be the verdict. Ill post more pictures of that wear area.
    - I bought both driver and passenger. Had toyota double check the numbers as well. I also tested the seal on the axle before I installed it into the trans. Driver side is correct.
    - On the 3rd try, I had the seal recessed around 3mm. When the axle installed, it actually pushed the seal in more. Now it sits about 2mm-2.3mm
  10. Turbo Heart
    I'm still learning of the CVT transmission, as I always worked on Toyota 5 speeds lol
    I used to avoid autos but the CVT design is pretty interesting.
    Just picked up a transmission from a salvage yard.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Hope you have a hybrid capable code reader.
  12. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    First off, it is a planetary gear trans, not CVT. Correct me if I am wrong but I did read this elsewhere.
    If the seal is tight on the shaft but the shaft moves the movement will ruin the seal and leak. Many seal replacements on worn shafts leak, the area the seal touches can wear smooth and allow fluid by. Old man tricks include not pushing the seal in so far as normal, so the seal lip touches a "new" area on the shaft and using emery paper to scuff the shaft surface a bit. But again, if the shaft moves it will ruin the seal.
    Sorry
  13. Turbo Heart
    I compared the inner tube for bearing play with the other transmission I just purchased, and there is significant play in my original transmission. Maybe I can rebuild the transmission and keep it as a spare? (replace the worn bearings/race)
    I start removing the transmission tomorrow.
  14. ChapmanF
    18,959
    It looks like Toyota can still sell you the differential side gears (41331H) and their thrust washers, differential case bearings and shims and so on, even the differential case itself if it comes to that.
    TRANSAXLE ASSY(HEV OR BEV OR FCEV). 2007 Toyota Prius | Toyota Parts Center Online
    What you'll notice is that the thrust washers and bearing shims come in a range of sizes, and your rebuild has to include a somewhat tedious process of determining the sizes you need and ordering those. If you go to the web site for Art's Automotive in Berkeley, CA, you can read an old article about how tedious that was for an old Gen 1 tranny rebuild he did, and why he decided not to do more of those.
  15. Turbo Heart
    I ended up putting in another lower-mileage transmission. It runs great. However I keep getting a battery code (cars been sitting for a month)
    I was getting P0AA6 and P3000
    One of the battery packs had a lower voltage than the rest. So i replaced it.
    I have to turn the code off via Techstream. The car drives great and the battery charges but once I turn the car off, P0AA6 returns. (P3000 no longer returns)
  16. mr_guy_mann
    4,109
    2,011
    NJ-USA
    P0AA6 is an isolation fault in the HV system. Where you getting that code before doing any of this work?
    If you look at the code screen in Techstream, there should be a little snowflake icon next to the P0AA6- that's the freezeframe data. Click on it and there should be a 3-digit "detail code" (or INF).
    When the hybrid control ecu first detects a problem, it sets a (general) INF of 526. Do not clear the codes. Power up the car again to ready. Read the codes and freezeframe again. The ecu should have done more testing and set another INF (611, 612, or something) that narrows down the suspect area.
  17. Turbo Heart
    I was not getting this code before. Popped on after car sat for a month as I replaced the transmission.
    Thank you for the info, I will check the INF code.
  18. Turbo Heart
    Update:
    New trans has no leaks. Drove the car and it drives great. (went for a 30 min drive)
    But once I drive for a bit, I get a warning light. And if I turn off the car, it wont start back up. I have to reset the codes to get it drivable again.
    Techstream codes are:
    P0AA6 Detail Code 2: 526 and Detail Code 3: 613
    Also got P0A80
    Going to use this to diagnose: https://attachments.priuschat.com/attachment-files/2018/04/145252_2006_Prius_RM_-_P0AA6.pdf
    Could I use a regular multimeter? (I dont own a megohmmeter)
  19. Turbo Heart
    New Update: Looks like the transmission I put in has a bad MG2.
    I used this thread to test the leads using a multimeter: Megger/ohm meter needed please!!!! | Page 3 | PriusChat"
    Post #4 and #9 helped quite a bit.
    I get ZERO resistance on all 3 leads of MG2.
    I get infinite resistance on all MG1 leads.
    Now comes the next part. I have two options:
    1 - Should I return this one, (still under 90 day warranty) and swap another one? Maybe this time Ill bring a multimeter with me and test the leads right there (usually comes with the MG wires attached but cut.) Can I just ground it out to the transmission itself?
    2 - Take the MG2 assembly from MY original transmission and put it into this junkyard one.
    Going to start taking things apart tomorrow.
    Tombukt2 likes this.
  20. Tombukt2
    13,809
    2,504
    Durham NC
    When you're doing this you're not running one of the leads to ground right You're testing between the three wires as if you were testing a stator or something like that? Just curious
