Battery ECU secrets and teardown (warning: geek content)
Discussion in 'Gen 2 Prius Technical Discussion' started by pEEf, Oct 23, 2010.
  1. pEEf
    pEEf Engineer - EV nut
    720
    580
    Berkeley, CA
    LOL!
    I said as I meant; The Battery ECU has no communication means other than the CAN bus. It would be pretty silly of Toyota to run the CAN bus all the way to the back of the car just to terminate it! =)
    JPR and dave77 like this.
  2. Mayyas
    Mayyas New Member
    hello,
    I there any one can provide Data sheet for Prius III battery control unit, I am trying to generate these signals using cRIO to eliminate the battery control unit
  3. Mayyas
    Mayyas New Member
    Thanks Peef for the info,
    is there any way that I can get the data sheet for the battery control unit for Prius III, I am trying to eliminate the battery ECU and use the cRIO to regenerate these signals
    Thanks in advance
  4. pEEf
    720
    580
    Berkeley, CA
    There is no "data sheet". Toyota (and all auto manufacturers) keep these things secret. This is why I reverse-engineered the Gen II unit in the first place.
    JPR likes this.
  5. petrik
    petrik New Member
    Finland
    If you guys have the engine ecu, would be most interested to see the processor type and if there is a backdoor to access it ?
    My long term hobby involves disassembling engine ecus and if the firmware is made avail could have a go at it...
    SFO likes this.
  6. lesdit
    lesdit New Member
    32
    United States
    Hi Peef,
    Would you like to share some tidbits of knowledge on the tactic you chose to encourage the ICE to stay off ?
    I understand you inserted a CAN bus 'message filter' to isolate it. Even just a few words on the frames you need to modify would be helpful.
    Thanks!
    SFO and [email protected] like this.
  7. engineer hassan
    engineer hassan New Member
    saudia
    2012 Prius Alpha
    #27 engineer hassan, Apr 26, 2015
  8. engineer hassan
    saudia
    2012 Prius Alpha
    Hi , In Prius alpha scanner shows the two fault codes as "P31AB hybrid battery cell low voltage" and "P31AA-123 Hybrid battery cell high voltage". even i checked all cells voltage one by one. But one point is very important a main relay circuit that is consisted on three relays as one for + battery line switched and one for -ve battery line switched . these two relays are not going to ON .battery voltage are 212v DC.Each cell has own 3.8volt. These are controlling by the Hybrid ECU system. ECU is not going to energize the relay to transfer the battery voltage forward on converter inverter unit. if i try to manually energize these two relay and transfer the battery voltage on the inverter converter unit . there could be a problem or not . please replay...thanks
  9. Hybrid Battery Exchange
    83
    94
    Gresham, OR
    Don't mean to bump such an old thread but I feel like the original poster deserves more recognition.
    I've been noticing more and more cars plagued by corrosion at the B connector requiring replacement of the sensor harness and the battery computer. The harness is available from Toyota brand new for around $70 but the computer is around $700, forcing everyone to get a used one on ebay. On most of these computers where the circuit board isn't burned out the connector can be replaced and put back into operation. The problem is finding this connector receptacle. Is there a vendor that sells these?
    m.wynn likes this.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,838
    Clearwater, Florida
    Try mouser. But if the harness is available then you could take the board to your bench Remove the rotten connector cut the end off the new harness and solder it to the board.
  11. Hybrid Battery Exchange
    83
    94
    Gresham, OR
    That would probably create a new set of problems, particularly with packaging since there are 2 rows the wires would be laying one on top of the other.
    After scouring the web I have been able to locate a company in China that makes them but minimum order is about 4000 units. Going to have them send me samples and go from there.
    JPR, SFO and edthefox5 like this.
  12. edthefox5
    10,096
    4,838
    Clearwater, Florida
    Ok. Have never seen how it lays in the box when installed.
    Yeah Alibaba.
  13. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Yeah, most all of pEEf's contributions here were of mind blowing proportions. Shame he disappeared.
    So is the crusty B connector issue specific to a particular generation of Prius and is there a specific code(s) stored which may be a tip-off?.. Thanks(y)...
    SFO and NortTexSalv04Prius like this.
  14. strawbrad
    953
    1,007
    The battery ECU fires are covered here. The corrosion tends to let the magic smoke out before any codes are stored.
    The battery fires at ECU sense connector thread | PriusChat
    m.wynn and SFO like this.
  15. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Peef is over on the Tesla forums now.
    You want to see mind blowing. He has managed to get access to the car diagnostic systems and more.
    Great for folks that are out of warranty or want to work on their own vehicles.
    Teslas are incredibly inaccessible vehicles. Independent mechanics can't even buy the diagnostic tools and software from Tesla.
    SFO and m.wynn like this.
  16. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    I love to hear stuff like this because to me there's no excuse for blocking folks who rightfully bought a vehicle to attempt to fix it themselves.
    drees, m.wynn and VFerdman like this.
  17. Hybrid Battery Exchange
    83
    94
    Gresham, OR
    This happens in stages.
    Stage 1 corrosion builds on the sensing harness and battery ecu pins
    Stage 2 corrosion bridges 2 pins together causing a strange reading in the battery live data, I often see negative value for the blocks
    Stage 3 corrosion bridges multiple pins together causing the sensing ECU and battery harness to burn out, the energy for this is taken from multiple modules. I find packs like this have low voltage readings on modules 1 through 4 while the rest are fine. I attached an image of what it looks like.
    #37 Hybrid Battery Exchange, Apr 29, 2018
    JPR and m.wynn like this.
  18. Hybrid Battery Exchange
    83
    94
    Gresham, OR
    Got my hands on a sample batch of these connectors and replaced it on a battery computer that was working fine but had corrosion on the pins, will finish a few more a test them each out for a few months to see how they hold up. I touched up a few solder joints after taking the picture (for the eagle eyed).
    #38 Hybrid Battery Exchange, Apr 29, 2018
    Rossini2, SFO, renatomn74 and 2 others like this.
  19. Hybrid Battery Exchange
    83
    94
    Gresham, OR
    Raytheeagle and m.wynn like this.
  20. Hybrid Battery Exchange
    83
    94
    Gresham, OR
    I guess I've hit some sort of a limit, no matter how many times I attach the picture it won't post. IMGUR to the rescue!
    #40 Hybrid Battery Exchange, Apr 29, 2018
    m.wynn likes this.
