Battery purchase mistake?
Discussion in 'Gen 3 Prius Main Forum' started by PriusKyle, Jun 25, 2023.
  1. PriusKyle
    PriusKyle Junior Member
    82
    16
    Virginia
    Hi all,
    Just purchased and ready to replace current 12v aux battery in my 2011 Prius; I bought an Optima yellow top from Amazon that says it fits my car.
    I recently noticed my current battery shows the word “lithium” on it but my new purchase does not and in the description from Amazon specs shows the word “lead”; I’m not doubting it “fits” my car but is it inferior to my current battery cause it’s not lithium?
    Thx!
  2. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    Was the lithium battery an experiment? What's wrong with it? Standard 12-volt "aux" batteries in Prii are lead-acid, more specifically the AGM subspecies.
  3. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    If you're running a LifePo 12 volt battery then it's probably a third the size of the 12 volt that was there I run some in my power sports equipment they are tiny but that's not what came with the car I'm not sure what you were reading I'd love to see that label how heavy is that battery? It should be about 3 lb or something under five I'm sure in that size It would be quite small
  4. JC91006
    16,936
    8,647
    Can you tell me what brand battery you have that says "lithium"? That would be great to have a 12v lithium battery. Although the standard battery from the factory is an AGM sealed battery, a lithium option sounds interesting
  5. bisco
    52,863
    someone here has been running lithium and reporting updates for years
  6. bisco
    52,863
    who put the last battery in?
  7. JC91006
    16,936
    8,647
    You're probably right, I just don't think I've come across them enough to remember. Too expensive to pay for Lithium when you can get OEM for much less and it'll last many reliable years
  8. bisco
    52,863
  9. PriusKyle
    82
    16
    Virginia
    Not an experiment; it was the original battery when I got the 2011 Prius from CarMax years ago. Didn’t realize these Prius came stock with lead acid which I understand is inferior to lithium.
  10. PriusKyle
    82
    16
    Virginia
  11. PriusKyle
    82
    16
    Virginia
  12. PriusKyle
    82
    16
    Virginia
    Not sure if this was the battery you wanted to see; this is what came with my 2011 Prius when I hit it years ago from CarMax that I was planning to replace with the optima lead acid from Amazon.
  13. PriusKyle
    82
    16
    Virginia
  14. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    Then it was the previous owner's experiment. Why do you want to replace it? Lithium isn't necessarily superior overall, when the charging system isn't designed for it.
  15. PriusKyle
    82
    16
    Virginia
    Not sure but it was the battery that was in my 2011 Prius when I got the car from CarMax years ago.
  16. bisco
    52,863
    Most are concerned about the charging bms, but the above link seems to work well.
    cost is an issue for most I suspect, but worries about fires are another
  17. bisco
    52,863
    #17 bisco, Jun 26, 2023
  18. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    The battery in that photo says it's an AGM----as was the original battery.
  19. PriusKyle
    82
    16
    Virginia
    I was in the hospital for Cervical fusion and my car sat for over 3 weeks and the car wouldn’t start when I got back; jumped it and drove the car for an hour hoping to recharge and save battery. I eventually bought a lead acid optima battery from Amazon but not sure if I should swap it now that it just dawned on me I got a lead acid as opposed to the current lithium; from what I can tell, lithium are supposed to be superior for longevity and reliability etc.
    You think I’ll be ok with the lead acid optima and just install it without obsessing with lithium type that came with mine originally?
  20. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    Might be smart to get rid of that lead acid battery and put in an AGM (absorbed glass mat) battery.
    The lead acid battery gives off a poisioness gas that will circulate through the car.
    The oem Toyota battery has a 7 year warranty, and most last that long.
    Since the 12v battery does not start the engine, there really is not any advantage to a lithium battery.
    For the Hybrid battery, probably. "If" you reprogram the ecu to let it know it is charging a lithium battery.
    #20 ASRDogman, Jun 26, 2023
