Battery starting to deplete more quickly
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Deleted member 111882, May 23, 2022.
  1. So, I seem to be getting a little less than the promised range… but most bizarre is if I have, say, 3 miles, and I start the car in the morning, I have a trip of 1.6 miles, very gentle hills up and down and acceleration… and the displayed number of miles depletes much faster than 1.6 miles. Now I can understand small variability, but I’ve gradually noticed larger discrepancies in low-mile range in the past two years.
    Is the traction battery starting to fail?
    52,789
    not at all. you can expect some degradation, especially in the first few years. but there are too many variables to know exactly where you stand. you would have to do some rigorous testing, but then, you have nothing to compare to when new.
    one thing you can do is see how many kwh it takes to fill from empty.
    your description of less miles at low battery doesn't fit any scientific explanation, and is more likely an anomaly of the guess o' meter.
    btw, toyota's description of a failing battery is when it won't start the engine. you will get dash lights, and there will be codes.
  3. MalachyNG
    MalachyNG Active Member
    304
    227
    Northern NY
    2022 Prius Prime
    What is your mile/kwh for those days? If you are carrying anything on the roof, using heat or ac more, etc you'll see a ding on your efficiency. A stuck brake caliper can also add a lot of drag - have you noticed pulling to one side, lots of brake dust or a rubber smell around a wheel?
    Could be a few things or a combination of things. The distance display is just a best guess based on your average driving style over time, it's not an exact amount of range. If you deviate from the norm it'll be less accurate.
    jerrymildred likes this.
    52,789
    tires too
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    As already said, the key is your m/kWh. To and from work, I get about 30 miles of range with 5.6-5.8 m/kWh. Today, I got about 26 miles with 4.6 m/kWh. Yesterday was even worse.
    Even so, some capacity loss is almost guaranteed after five years. I bought mine used with 24k miles, so I don't know what it took to charge it when it was new. But since I started checking 2-1/2 years ago, it has stayed pretty consistent. I did take a substantial and abrupt dip in March, but then mysteriously bounced back. And, obviously, there is some variability in how deep into the HV charge I had gone when I shut it off.
    Tideland Prius likes this.
  6. I think mine is avg. 5.3 mi/kWh, but I'm not sure how to track it each month like you're doing.
  7. MalachyNG
    304
    227
    Northern NY
    2022 Prius Prime
    There are screens in your dash display with monthly, daily MPG and m/kwh. The car fudges those a little bit but what you're looking for is a change in the numbers. If last week every day was at 5 m/kwh and then this week is down to 2.5 then that might explain the faster "loss" of range - the car is giving you an estimate based on going 5 miles per kwh but instead it's only making it 2.5 miles. If it's still reading 5 and you're not getting as far then you'd want to look into an issue with the battery.
    jerrymildred and Tideland Prius like this.
  8. jerrymildred
    11,517
    14,164
    Tampa, FL
    Do you mean the screen shot from my spreadsheet in post #5? As the label says, it's kWh, not m/kWh and capacity, not efficiency. It is simply charting how many kWh it takes to fill a depleted EV portion of the battery. I try to remember to check it every few months. Sometimes I check it more often. Just trying to get an idea how much charge it's able to hold as it ages. Because the meter I have installed on my 240V outlet circuit rounds the energy off to whole kilowatts when it reached 10, I have to reset it to zero to get any kind of a precise reading. That means more work later when I gas up and record the kWh to go with that tank.
  9. It's always said 5.2 or 5.3 mi/kWh over the life of me using the vehicle. I can't recall a time when that number ever really changed.
  10. jerrymildred
    11,517
    14,164
    Tampa, FL
    The daily screen stays that consistent for you? Mine's all over the plave because I'm always going different places on different roads at different speeds.
  11. Wait I didn't see that screen, I have Drive Monitor 2. I'll have to check that later.
  12. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    You need to check the Eco Diary. Both Daily log and Monthly log.
    Where you live, the seasonal miles/kWh fluctuate a lot. If you are maintaining a 5.2miles/kWh average on Drive Monitor 2, that means your summertime EV efficiency is more like 6-7 miles/kWh. Your wintertime EV efficiency is most likely to be 3-4miles/kWh range. Here is my monthly log of miles/kWh.
    But what you really want to find out is the daily fluctuation. If it is low, then your GOM will reduce the EV miles displays. If it is high, then it will show a higher guesstimate range. This is an example of my daily log.
  13. Nevermind I found it, normal readings increasing as the weather gets warmer with some variations daily due to some short trips.
  14. Salamander_King
    11,024
    8,977
    New England
    If your recent days or weeks of miles/kWh are showing normal efficiency for this time of the year, but you are still being able to drive less total EV range, then it's a good indication that some battery degradation has occurred. One another way to check is the battery capacity change as shown by @jerrymildred in comment #5. But for that, you had to have measured the total kWh used to fully charge the traction battery by using a kWh meter. If you don't have any historical data, it may be difficult to prove the battery capacity loss.
    But for the short distance remaining on the GOM, I would not worry too much. That is just a guess for the last few miles left from the previous day's trip. I think it is a totally different situation between the last few miles of the trip on EV mode the day before vs the same EV range on the GOM but next morning for a short trip starting from cold.
  15. jerrymildred
    11,517
    14,164
    Tampa, FL
    My efficiency is going down due to the increased heat and A/C load. I ran out of battery a half mile from work and again less than a half mile from home.
  16. With some more experimentation, I found that the last 2.5 miles of stated range are depleting very quickly, even if it is calm wind, flat or short slopes less than 3º, and at 25 mph. With a low stated range, the range just quickly depletes, like, it'll skip from 1.6 miles to 1.4 miles, or quickly run through 1.4 to 1.3 to 1.2... here is what I mean:
    Also, if I make that same trip with more miles on the battery, like, 20 or 30, then the range depletes at a much-closer-to-normal rate.
    So, I'm wondering how to fix this, or if there are significant dendrites already on the battery.
  17. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    If you have an OBDII adapter, you could use Dr. Prius to check for a bad cell.
  18. bisco
    52,789
    if you have a 'bad' cell, you'll get a light and trouble code. o/p's description of the problem, while unusual, is not going to find an answer.
    the guess o meter behaving badly at low remaining range doesn't tell us anything.
    tech stream may have a sophisticated way of measuring battery capacity and kwh usage over those remaining miles vs preceding miles.
    if there is a problem, it is more likely a computer glitch than a battery issue.
    Salamander_King and jerrymildred like this.
  19. Salamander_King
    11,024
    8,977
    New England
    +1 I totally agree.
    The GOM sowing the remaining miles is so unreliable, that I would not worry about the problem OP is describing. Even with my 10 mo old PP, on the same route, the remaining last few miles shown on the GOM fluctuate widely from day to day.
    The only reliable measure of battery capacity loss is measuring the number of kWh used to charge 100% of the traction battery over time. The second best method is to repeat the same route travel under very similar driving conditions and record the TOTAL EV range you can drive from 100% of the charge. But both methods show very wide variability from day to day such that a one-time comparison has no meaning. It has to be repeated large numbers of times to be statistically significant.
  20. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    Okay, poor phrasing on my part.
    Since the OP lists his vehicle as a 2017 PP, it's possible that one or more cells is getting weak. That's a typical scenario for any multi-cell pack. There will always be one or two cells that are weaker than the others. That cell gets repeatedly used to the limits the PP allows while the others don't. The weak cell eventually dominates the pack's life since the computer will report 0% capacity when the weak cell is exhausted. This will show up as a good pack voltage that drops quickly at the end of the discharge. The computer may or may not be able to learn this behaviour and work it into the GOM calculation. This will *NOT* drop any codes because that's just the way that multi-cell battery packs work. Besides, Toyota doesn't warranty a battery for loss of capacity and dropping a code might result in a battery warranty claim. Dr. Prius will show this situation if you take a measurement at a time when the remaining capacity is low, ideally at 0%. You'll see most of the cells with a nice healthy voltage and one or two that are down at the bottom end of the acceptable range. If *ALL* the cells are a similar voltage, regardless of what that voltage is, the pack is healthy.
    Ed
