Beep when braking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mrstop, Jul 4, 2018.
  1. Kate M
    Kate M Junior Member
    64
  2. Kate M
    64
    Found a video that matches the sound and it seems to be Brake Booster. Taking it to dealer tomorrow for diagnostic.
    Bought this car two days ago and love it (my 2005 was totaled in a rear end accident 3 weeks ago).
    If this is a major repair I'll be devastated.
    52,807
    that'ss just the fluid pump filling the accumulator, don't waste your money.
  4. douglasjre
    douglasjre Senior Member
    2,249
    751
    Null, NL
    Ur trunk prob isn't fully closed. Most often because u have a full size spare pushing up the deck
  5. Kate M
    64
    Just heard from Toyota service dept...
    Accumulator (nitrogen tank) and Master Cylinder need replacement
  6. bisco
    52,807
    they'll do anythink for a buck these days
  7. rogerdpack
    rogerdpack Junior Member
    82
    Enoch, UT
    For me had "when braking, all the warning lights would flash on, then off immediately", trying to investigate also noticed an (apparently normal) whining noise passenger side of the engine bay (not the whining noise of the inverter cooling pump, which is on the driver side). Somewhere said whining might be the "oil pump" which reminded me to check oil level, which turned out to be way lower than a quart low...not your problem but thought I'd mention it in case it helped anybody :)
  8. douglasjre
    2,249
    751
    Null, NL
    I'm confused. What just happened?
