Featured Best answer I've seen yet from Toyota about going full EV
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Marine Ray, Nov 15, 2019.
  1. El Dobro
    El Dobro A Member
    7,106
    3,282
    The GM plug-ins have battery heaters that keep it warm during those times where it needs heat while plugged in. You can also use the remote or an APP to preheat the cabin.
  2. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    Thanks. I remember reading that you can't plug in a Prime for charging and then use that power to preheat the gas engine once the battery is full. That seemed like a huge missed opportunity to me. Really? I gotta plug it in twice?
    52,891
    don't we already have these with bolt and leaf?
  4. El Dobro
    El Dobro A Member
    7,106
    3,282
    There's a Nissan dealer near a friend of mine, that has free charging. They have two level 2 AC stations and a CHAdeMO/CCS station. I would imagine they wouldn't have a CCS plug if they didn't want others there.
  5. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    I'll call them a fair start. I think it'll take a few more shots at the target to get it right.
  6. hill
    9,041
    Kia, Tesla, Hyundai Electric Cars too. Having liquid thermal management, they also scavenge heat from the electric motors (in addition to resistance Heat) to heat the cabin, much like gas burners do. iirc, on the Nero you can order a heat pump to supplement the other heat sources.
    salyavin likes this.
  7. pruiskip
    pruiskip Junior Member
    Lecanto, FL USA
    2020 Prius Prime
    I plug in my 2020 Prime in at least three times a day. It only costs 12 cents per hour. Now with 1,780 miles, I have only put 2 gallons of gasoline in it.
    vvillovv likes this.
  8. bisco
    52,891
    what improvements do you think would jump sales?
  9. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    Never having driven either car, I can only offer a very limited viewpoint. The leaf looks like it needs a little "more" in the sense that I keep hearing about problems related to this or that, and it's often temperature management. I feel like it could be fixed, and is overall closer to the target.
    On the other hand the Bolt clearly needs less of something. It's a $20-25k car with a $38k price tag. I don't know what to cut but it needs less content somehow.
    Dimitrij likes this.
  10. bisco
    52,891
    thats old leaf news from the south, but the rep lives on. both cars are very reasonably priced after all discounts, rebates and tax credits.
    they will never save you money though, so the consumer has to want a bev. thats the rub these days.
  11. Trollbait
    12,832
    Maybe not the Leaf. It's an air cooled battery. I think its battery heater is like the Primes, for keeping it above freezing, but not getting to optimum temperature.
    Many do, well not the engine block, and the ones with air cooled batteries only heat enough to prevent damage in freezing temperatures. How well they work varies.
    The EVSE is a limiting factor. With Level 1, these things would have to be done sequentially. The gen1 Volt only preheated the cabin when Level 2 was used. It has been to made to work on Level 1, but depending on outside temperatures, cabin heating might require pulling energy off the battery. Throw in a block heater, and you might have the situation where the block or cabin has cooled off while heating the other. With a PHEV that can charge up in 6 hours on Level 1, many probably wouldn't want to pay for a Level 2 just for engine block heating.
    The European 2020 Ioniq and Kona Electrics have an optional battery heater. Don't know it means a more powerful one for colder climes, or that the base system just cools.
  12. Dimitrij
    Dimitrij Active Member
    405
    202
    Virginia
    From where I sit: Neither EV was intended to be a commercial product in their own right. Instead, for Nissan and GM's they are primarily the cost of license to continue selling ICE cars in the current regulatory environment. No wonder that both EV are geared towards meeting the stick-and-carrot requirements rather than satisfying consumers.
    IMO the Leaf and the Bolt need to be of the Murano/Equinox size, with the following choices available to the buyer as a minimum: Multiple battery sizes (and perhaps a range extender), available AWD, and advanced battery TMS incl. waste heat management. Plus a voluntary equivalent of what VW is doing through Electrify America to support the fleet.
  13. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Preheat what? Since EV driving can far outlast engine coolant, that would be a pointless feature. Engine block heating comes from a separate plug anyway. In other words, check your source. Something clearly isn't right with that claim.
    You can preheat the cabin (aka "preconditioning") any time you want, regardless of battery level. Without being plugged in, it will draw directly from the battery. And yes, it will dip into HV capacity if called upon. While plugged into 240-volt, it will do a combination of rapid pull from the wall, a little bit of battery, then pull from the wall again. That basically warms up everything using the heat-pump.
    There is also the battery-warmer. I'm not actually sure if that operates without being plugged in. But it certainly does work when you are. With temperatures below 0°F parked outside without any protection, mine was kept at a comfortable 39°F last year. That's what the lithium chemistry needs to operate more efficiently. Below freezing, electrical resistance increases quite a bit.
  14. bwilson4web
    16,552
    • 0-60 mph in 5 seconds
    • 75 mi EV range
    • 100 kW fast DC charger
    Tideland Prius and vvillovv like this.
  15. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
  16. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    Yeah this isn't going anywhere until the sticker prices (meaning before tax schemes) are slightly below those of gas cars.
  17. vvillovv
    4,337
    1,519
    NY
    Since I haven't been spoiled by Tesla specs yet, and still live happily with Prime specs,
    I'd be happy in a Toyota EV with:
    50 mile EV EPA rated range
    0-60 mph in 9 secs ( wait can the prime already do that sometimes)?
    95 mph top EV speed. That might be fun to test the top end of that EV curve.
    2 hour L2 - 4 hour L1 charge times
    optional equipment:
    add an atkinson cycle range extender cold weather heater
    inverter coolant heater
    traction pack top side and between module block heater.
    an array of solar wind turbine and ported body panels
    lift kit with aero skirts
    adjustable hydraulic suspension
    adjustable air suspension
    #97 vvillovv, Nov 17, 2019
  18. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    My comment was primarily concerning preheating the gas engine block in a PHEV.
    I'm glad to hear that the grid tied cabin heating is more widespread than I'd thought. As for integrating the block heater in a PHEV, you seem to have confirmed my worst fear: "Engine block heating comes from a separate plug anyway." It just seems like an unbelievable engineering oversight in a family of cars that has already taken such unusually advanced steps as exhaust heat recovery and thermos bottles. Rankles me a bit that they'd miss such a big opportunity in terms of overall energy management.
    Obviously not every user needs it; there's plenty of evidence of people who like to pretend their Prime doesn't even have a gas engine. Maybe Toyota isn't selling many to people who actually wanted a PHEV for use beyond battery range? Anyhow it would be trivial to make its use a menu option in the system they use for the charging preferences and cabin preheat details. It just seems flat out dumb that they didn't provision a line from the charger socket to an underhood connector for an optional block heater.
    #98 Leadfoot J. McCoalroller, Nov 17, 2019
  19. hill
    9,041
    at what price .....
    BTW - the 0-60mph time for the Prime is ~ 10sec.
  20. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    Not until I know how much I can save with the one that needs 11.5 seconds, tops out at 90 & needs double those charge times.
