Best mode for long distance driving?
Discussion in 'Prime Fuel Economy & EV Range' started by Ed From Syracuse, Apr 21, 2017.
  1. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    What is the 'charge mode' advantage in this situation over just looking for a gas station?
  2. CharlesH
    2,798
    1,166
    Roseville, CA
    EV-Auto mode tries to use the most efficient energy source at that instant, be it gasoline or electricity. This is how EV mode worked on the first-generation Prius Plug-in. But users complained about the ICE turning on "unnecessarily", so Toyota changed the programming in the Prime to provide both a "most efficient power source" mode and an "EV only unless you floor it" mode. They even added a "Charge" mode to allow the ICE to recharge the battery, even though there are only few situations where the conversion losses are mitigated by other factors, which most non-sophisticated uses are not likely to sort out.
    jerrymildred likes this.
  3. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    EV mode is even if you floor it (most of times).
    There is another reason for EV Auto in the Prime and it is the available power (for overtaking and such), EV mode is limited to the 68 kW the battery system can provide, EV Auto has the full 91 kW available.
  4. bwilson4web
    16,538
    Risk avoidance. The car has very accurate SOC even at the low end so the driver can park safely. In contrast, gas is less precise which can lead to unsafe, involuntary stopping .
    Samprocat likes this.
  5. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    OK got you...I am avoiding all risks by refueling well before "low gas" comes on...
    bwilson4web likes this.
  6. bwilson4web
    16,538
    That is a good strategy but I like to know the performance limits BEFORE reality makes its appearance. Then I share them with the community. These are obscure and often difficult places to be but not impossible.
    giora likes this.
  7. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    I drove from Northern Minnesota back to the Twin Cities today. Here's some real-world data from that...
    charge-mode = 40.0 miles
    charge-mode = 37.8 MPG
    It took 38 minutes at 66 mph with an outside temperature of 64°F and a light crosswind to recharge the battery-pack form 0 to 80%. I took advantage of that recharged 25 miles of EV (estimated) to keep the engine off while making our two stops along the way and when getting trapped in weekend traffic at a major highway junction. These were the final results...
    overall = 153.7 miles
    overall = 60.4 MPG
    In other words, just charge it. If you'd like engine-generated electricity for use later, go ahead. There does not appear to be any penalty for doing so.
    #27 john1701a, Apr 23, 2017
    unicorn, giora and bwilson4web like this.
  8. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Thank you for searching the performance limits and sharing, good to know and I really appreciate it.
    Maybe better way to present it in a prescription will be: If "low fuel" indicator comes on before you had a chance to refuel...instead of: when.
  9. bwilson4web
    16,538
    I'm not so optimistic. <GRINS>
    Prodigyplace likes this.
  10. unicorn
    unicorn Member
    48
    EU
    Let's assume:
    - depleted battery
    - 65 miles at 65 mph
    There are three strategies at least:
    1. HV mode for 65 miles --> 55 mpg (65 mph)
    see a diagram(#80) Prius Prime Plus in my hands | Page 4 | PriusChat
    on the other hand, the HV advantage is the ability to conserve the battery power
    2. so called CHG/EV mode --> 61.4 mpg (66 mph)
    65 miles = 40 miles (Charge, 37.8 mpg) + 25 miles (EV, 0 mpg)
    (37.8/40) x (40+25) = 61.4 mpg
    3. EV Auto mode for 65 miles (with depleted battery) --> ??? mpg
    comparable data: 702 miles, 64.1 mpg, avg. 54 mph, #14
    see EV Auto strategy:
    It would be interesting to compare the mentioned strategies under the same conditions.
    Correct me, if I'm wrong.
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    Thanks, Charles. I'd been wondering about the difference between EV in mine & EV in the Prime since it had the added Auto feature.
  12. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The additional 25 EV miles resulted from the forced charge were not achieved at 66 mph but, as I understand, mostly at city driving.
    EV Auto with depleted battery??
    #32 giora, Apr 23, 2017
  13. john1701a
    12,840
    5,312
    58
    First, keep in mind that "city" is a term that's very misleading. Some people think of it as slow speed with lots of stoplights. Other people think of it as anything goes suburb travel... not highway. They are labeled the same, yet the two yield very different results. They really should be separate categories, like the rating system in the UK.
    Second, the use of the term "highway" is even worse. It spans any speed from 55 to 80, which vary drastically for efficiency results. It also includes hard-accelerations for some people's measure and is only cruising for others. Whether or not you are steady cruising or passing vehicles makes a difference too.
    With all that said, my particular test yesterday included the variety of "highway" driving with charge-mode generated EV miles. I took advantage of that electricity elsewhere (scenarios thought of as non-highway) but did still include 2 hard-accelerations onto the highway and some electric-only cruising at high-speed. The goal was to collect data from an ordinary trip... which in my case was extremely realistic, since I was traveling in tandem with 2 other vehicles.
    Long story short, this served as an example of diminishing returns. You can indeed squeeze out greater efficiency if you so desire, but there isn't much of a point. Once you achieve 60 MPG fueled by only gas, you can consume the resulting power as you desire. The sizeable gain has already been achieved. The next big step is simply plugging in when you can.
  14. bisco
    52,863
    if there's no penalty for charging the engine with gasoline, toyota may get a physics award, and come out with a new line of ev's you never need to plug in.;)
    economically, at $2.20/g vs 24 cents per kWh, i would be much better off using charge mode all the time. environmentally, i'm not so sure.
  15. john1701a
    12,840
    5,312
    58
    Overall, like with the hybrid, that actually did end up to be the case. It boils down to how the generated electricity is used afterward. Used wisely, there can indeed be a gain. Used poorly, there will be a penalty.
    That's why different hybrid systems yield different results.
  16. unicorn
    unicorn Member
    48
    EU
    Just to have the same initial conditions.
    But I agree, regarding to EV Auto functionality is better to start with the recharged battery.
  17. Ed From Syracuse
    Ed From Syracuse Junior Member
    28
    35
    Syracuse
    Thanks, that explains slot.
  18. Ed From Syracuse
    28
    35
    Syracuse
    Thanks guys, the suggestion helped. Going down to NYC I plan on using Eco EV-Auto on CC and see how it dose going up hills. Depending how it handles coming back to Syracuse I am going select Normal HV.
    On another matter, I will gas up 93 no ethanol Top tier if I can find it. Or should I just use normal 89. Because full ups are longer than normal (three to four months) I read to use TopTier no ethanol .
  19. JoePriusPrime
    JoePriusPrime Member
    46
    35
    Denver, CO
    I recommend not using cruise control for uphill and downhill areas because ICE will kick in trying to maintain set speed. When it's off cruise control gliding downhill you can see the wheels fully charging the battery with ICE off.
  20. bisco
    52,863
    just use regular 87, and make sure the gas doesn't sit in the tank longer than 6 months. don't waste your money on higher octane.
    i haven't filled up since october 27, 2016, and she's running fine.
    jburke313 and jerrymildred like this.
